[postgis-users] function to convert meters into degrees without reprojections
Paul Ramsey
pramsey at refractions.net
Fri Mar 30 11:03:28 PDT 2007
THEETEN Franck wrote:
> Hi Everybody,
> A few days ago I had a problem with projection units.
> I had a series of points in WGS 84 (with a projection which uses decimal
> degrees as unit) and I needed to trace a circle around them, with a
> radius specified in meter.
> The 'Buffer()' function from the postgis library allows the definition
> of a circle around a geometry, but it didn't work in this situation
> because the radius value must be expressed in the same unit as the
> reference point.
> I found on the Postgis mailing list some solutions which used the
> definition of a constant value allowing conversions between degrees and
> meters.
> But it was an unsatisfactory answer for my problem because the result of
> this conversion varies with the latitude.
I wonder if a quick utility function could make this "kind" of thing
easier...
Basically, a
to_local_planar(geom_to_convert,geom_to_reference,'MAGICSTRING')
the function would use geom_to_reference to set up the bounds of the
transform, and the MAGICSTRING to choose the TYPE of transform (albers,
tm, stereographic, etc).
It would have two shorter forms with defaults:
to_local_planar(geom_to_convert, geom_to_reference) which just uses
transverse mercator
to_local_planar(geom_to_convert) which uses the input geometry as a
reference geometry
And of course, there would be the inverse, from_local_planar
This would allow
select from_local_planar(buffer(to_local_planar(the_geom), 100.0))
Or... we could wrap this stuff all up to do it "automagically" in the
cases where SRID = 4326... and only the people who exercised it outside
of the box (around the poles, say) would be duly punished.
P
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
