[postgis-users] Doesn't match
Leticia lgomez at itba.edu.ar
Sat Mar 31 08:56:28 PDT 2007
Hi,  I have a problem with the following queries.
I have a table with only these two "linestrings"
CREATE TABLE twolines (ID integer, the_geom geometry);
INSERT INTO twolines
SELECT 1, 'LINESTRING(122.303797468354 272,86 135.428571428571)'::geometry;
SELECT 2, 'LINESTRING(211.8125 272,86 153.588235294118)'::geometry;
Then, I have a Point generate as the intersection of these two lines:
CREATE TABLE points AS
SELECT the_geom
FROM
SELECT INTERSECTION(L1.the_geom, L2.the_geom) AS P
FROM twolines l1, twolines l2
WHERE intersects(l1.the_geom, l2.the_geom) AND l1.ID < l2.ID
) AS auxi(the_geom);
(This table contains 1 tuple: the intersection point)
Later, when I try to find out at which point theses lines were intersected
with theses points, I obtain ZERO tuples.
I tried with all of these:
SELECT *
FROM twolines l, points p
WHERE overlaps(l.the_geom, p.the_geom)
SELECT *
WHERE distance(l.the_geom, p.the_geom) = 0
SELECT *
WHERE contains(l.the_geom, p.the_geom)
All of these queries show that the only point that was generated by the
intersection of these two lines, not belongs to these two lines.
How can I fix it? There exists another form of making the same answer that
let me obtain the correct answer?
Obviously I tried to extract the problem, but I need to generate all the
points that can be obtain by the intersection of several lines and then
operate with the subsegments generated by these crosses.
Thanks a lot,
Leticia
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070331/e421f87a/attachment.html>
