[postgis-users] ERROR: ExteriorRing: geom is not a polygon
Obe, Regina robe.dnd at cityofboston.gov
Tue Oct 2 05:33:58 PDT 2007
Oops I guess I was missing a ) and had a typo in the name.  Try the below instead
SELECT ST_ExteriorRing(ST_GeometryN(the_geom, generate_series(1, ST_NumGeometries(the_geom))))
FROM ffh_rep
Yes it should run without any other statements.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas Laggner
Sent: Tuesday, October 02, 2007 8:21 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ERROR: ExteriorRing: geom is not a polygon
Hi Regina,
the first query gave me 595 hits (from 27303 total). 594 times there are
2 polygons in the multipolygon, 1 time there are 3.
So i have 26708 polygons and 595 Multipolygons, right?
should this query run without any other statements?
SELECT ST_ExterionRing(ST_GeometryN(the_geom, generate_series(1,
FROM ffh_rep
I get the Error at the FROM statement:
ERROR: syntax error at or near "FROM"
SQL Status:42601
Zeichen:96
cheers      Andreas
Obe, Regina schrieb:
> Andreas,
> You can use ST_NumGeometries
> If you just want to know the count of records that have more than one polygon in the multipolygon - then do something like - note for below I am also including ST_GeometryType which will tell you if the geometry field is a Multipolygon or geometry collection or multilinestring etc.  If it's a multilinestring then the ST_NumGeometries tells you the number of line strings, if it's a geometry collection - then it could be a mish mash of anything like opther multipolygons etc.  Hopefully you've only got multipolygons or polygons in there.
> SELECT count(gid) As totrecords, ST_GeometryType(the_geom) as the_type
> FROM sometable
> WHERE ST_NumGeometries(the_geom) > 1
> GROUP BY ST_GeometryType(the_geom)
> If you want to know the actual records
> SELECT * , ST_NumGeometries(the_geom) As numPolygons
> FROM sometable
> Will tell you what multipolygons have more than one polygon in each multipolygon
> Hope that helps,
> Regina
> Sent: Tuesday, October 02, 2007 6:45 AM
> Hi Regina,
> how can i be sure to have only one polygon in each multipolygon in a
> dataset with thousends of polygons? Exists a function to verify that?
> hasta luego      Andreas
>> Yes you do.  ST_ExteriorRing only deals with Polygons not multipolygons or geometry collections.
>> There are 2 ways to do it.
>> 1) If you have a multipolygon and you are sure you only have one polygon in each multipolygon, then you can do
>> SELECT ST_ExteriorRing(ST_GeometryN(the_geom,1))
>> FROM ffh_rep
>> 2) If you really have multipolygons and you want the exterior ring of each polygon - it's a bit trickier.  Try
>> SELECT ST_ExterionRing(ST_GeometryN(the_geom, generate_series(1, ST_NumGeometries(the_geom)))
>> FROM ffh_rep
>> If you have a set of GeometryCollection hmm that's even trickier.  I would guess 2 layers of series - let me know if that is the case.
>> Hope that helps,
>> Regina
>> Sent: Wednesday, September 26, 2007 7:00 AM
>> Subject: [postgis-users] ERROR: ExteriorRing: geom is not a polygon
>> Moin users,
>> i get an error starting with this query (i want to overlay tables
>> according to this
>> http://postgis.refractions.net/support/wiki/index.php?ExamplesOverlayTables
>> CREATE TEMP TABLE all_lines AS
>>    SELECT St_ExteriorRing (the_geom) AS the_geom FROM ffh_rep
>>    UNION ALL
>>    SELECT St_ExteriorRing (the_geom) AS the_geom FROM spa_rep;
>> do i have to force my source data to be polygons? How can i do that?
>> cheers      Andreas
>>> Not sure I quite understand the question.  You mean to store these 3 geometries separately so you can color code as needed or overlay as needed?
>>> In that case you would have 3 separate geometry fields
>>>   intersection(ffh_rep.the_geom, spa_rep.the_geom) As geomintersection, ffh_rep.the_geom As ffh_geom, spa_rep.the_geom As spa_geom
>>> For the ones where there is only udo or kai then I guess you can fill in the same geometry for all geometry fields.
>>> and then overlay them on your map as separate layers as needed
>>> or if you mean you just want it to look like figure 1 but not necessarily color coded, then you would do
>>> collect(ffh_rep.the_geom, spa_rep.the_geom) as geomcollection
>>> Hope that helps,
>>> Regina
>>> Sent: Thursday, August 30, 2007 7:24 AM
>>> Subject: Re: [postgis-users] Union of 7 datasets
>>> Moin Regina,
>>> the query you suggested is a very big step forward, but it does not
>>> exactly what i want to have  ;-)  ...  it seems to me i will need an
>>> intersection in one part and not a geomunion!! But i want to ask you:
>>> what it does correctly: I now have a union of all geometries from both
>>> source datasets.
>>> If i have a single udo (ffh_rep) that intersects no kai (spa_rep) the
>>> row only has the attributes from udo. Same thing i have with single kai.
>>> That is all correct.
>>> BUT: If udo and kai intersects i will not have new polygons!! For
>>> example: blue is udo (or ffh_rep) and yellow is kai (or spa_rep). I want
>>> to have three polygons than with blue only the attributes from udo,
>>> yellow only the attributes from kai AND the intersection, polygon number
>>> 3, the green one (blue with yellow points) with the attributes from udo
>>> and kai (figure1). And now i have one Polygon having the attributes from
>>> udo and kai (figure2).
>>> figure1:
>>> figure1
>>> figure2:
>>> figure2
>>> My query:
>>> drop table natura2000;
>>> create table natura2000
>>>     (ffh_name character varying(80),ffh_land character varying(3),ffh
>>> smallint,ffh_id smallint,
>>>      spa_name character varying(80),spa_land character varying(3),spa
>>> smallint,spa_id smallint)
>>>     with oids;
>>> select
>>> addgeometrycolumn('','natura2000','newgeom','31467','MULTIPOLYGON',2);
>>> alter table natura2000 drop constraint enforce_geotype_newgeom;
>>> insert into natura2000
>>> (ffh_name,ffh_land,ffh,ffh_id,spa_name,spa_land,spa,spa_id,newgeom)
>>>  select ffh_rep.ffh_name,ffh_rep.ffh_land,ffh_rep.ffh,ffh_rep.ffh_id,
>>>     spa_rep.spa_name,spa_rep.spa_land,spa_rep.spa,spa_rep.spa_id,
>>>     geomunion(ffh_rep.the_geom, spa_rep.the_geom) as newgeom
>>>   from ffh_rep inner join spa_rep
>>>     on (ffh_rep.the_geom && spa_rep.the_geom and
>>> intersects(ffh_rep.the_geom, spa_rep.the_geom))
>>>     union all
>>>  -- the second select gives you ffh_reps that have no spa_reps - your 15
>>>       null as spa_name, null as spa_land, null as spa, null as spa_id,
>>>       ffh_rep.the_geom as newgeom
>>>    from ffh_rep left join spa_rep
>>>     where spa_rep.the_geom is null
>>>     union all
>>>  -- and the 3rd gives you spa_reps that have no ffh_reps. - your 40
>>>     select  null as ffh_name, null as ffh_land, null as ffh, null as ffh_id,
>>>         spa_rep.the_geom AS newgeom
>>>     from spa_rep left join ffh_rep
>>>     where ffh_rep.the_geom is null;
>>> Cheers    Andreas
>>>> Andreas,
>>>> You would use the SQL UNION predicate like shown below (actually
>>>> slight correction - it is speedier to use UNION ALL especially when
>>>> you know there will not be dupiclates since it saves the processing of
>>>> sorting to get a distinct UNION does an implicit distinct)  - so I
>>>> have corrected below.
>>>> -  - I happened to insert comments in between which may have confused
>>>> you, but you should be able to run the whole thing as one statement or
>>>> if you prefer because of speed issues run each insert separately.
>>>> So  would be
>>>> INSERT INTO sometable(field1, field2,field3,field4, newgeom)
>>>>  SELECT udo.field1, udo.field2, kai.field3, kai.field4,
>>>> geomunion(udo.the_geom, kai.the_geom) AS newgeom
>>>>   FROM udo INNER JOIN kai ON (udo.the_geom && kai.the_geom AND
>>>> intersects(udo.the_geom, kai.the_geom))
>>>>   UNION ALL
>>>>  -- the second select gives you udos that have no kais - your 15
>>>>   SELECT udo.field1, udo.field2, NULL As field3, NULL As field4,
>>>> udo.the_geom AS newgeom
>>>>   FROM udo LEFT JOIN kai ON (udo.the_geom && kai.the_geom AND
>>>>   WHERE kai.the_geom IS NULL
>>>>  UNION ALL
>>>>  -- and the 3rd gives you kais that have no udos. - your 40
>>>>   SELECT NULL As field1, null As field2, kai.field3, kai.field4,
>>>> kai.the_geom AS newgeom
>>>>   FROM kai LEFT JOIN udo ON (udo.the_geom && kai.the_geom AND
>>>>   WHERE udo.the_geom IS NULL;
>>>> ----If FULL JOIN were to work (which in theory it should, but doesn't
>>>> seem to with Postgis functions  (HINT HINT: would be nice if
>>>> that worked and can be easily fixed (but sadly I think the issue is
>>>> deeper than Postgis and Geos) - you could write the above much simpler as)
>>>> COALESCE(geomunion(udo.the_geom, kai.the_geom), udo.the_geom,
>>>>   FROM udo FULL JOIN kai ON (udo.the_geom && kai.the_geom AND
>>>> Now if you have a lot of these and the tables are very similar in
>>>> nature and named in a predictable way then the way I usually handle it
>>>> is to write a pgsql function that dynamically generates the SQL
>>>> statement to execute either via a FOR loop and then executes the built
>>>> SQL or set of SQL statements or you could do a similar thing in some
>>>> scripted language like perl or php.
>>>> I take it SQL and pgsql and all that is fairly new to you so it might
>>>> be worthwhile (even though its a lot of typing) to do it the long cut
>>>> and paste way if nothing more than an exercise to get a feel of how
>>>> this all works and visualize the patterns at play.
>>>> I don't get the sense that I comprehend your full problem.
>>>> Unfortunately I don't have any experience with ArcGIS/ArcView ways of
>>>> doing things, so I'm not quite sure if there is an equivalent way in
>>>> PostGIS/PostgreSQL  world of doing the same kind of thing and what
>>>> exactly that thing is you are doing in ArcGIS.
>>>> Union has 3 meanings in PostGIS/PostgreSQL (actually stuff your
>>>> favorite spatial/DB here - all non-trivial spatial relational dbs
>>>> behave more or less the same)
>>>> 1) unioning of record sets (standard ANSI SQL UNION/UNION ALL) - which
>>>> is simply a way of stringing together a bunch of selects into a
>>>> single result set as shown above
>>>> 2)  unioning of 2 geometry fields like shown above with geomunion
>>>> 3) Aggregate  geomunion - aggregate variant of the above geomunion
>>>> function that groups and unions a whole setof geometries together but
>>>> requires you are grouping by some field or set of fields).
>>>> I must also mention there is collect (non-aggregate and aggregate
>>>> function) which often times is just as effective as the geomunion and
>>>> in general much faster processor wise.
>>>> Hope that helps,
>>>> Regina
>>>> Andreas Laggner
>>>> Sent: Tuesday, August 28, 2007 9:13 AM
>>>>>  Sounds like you would have to go with a full join type thing with
>>>> workaround I described below (last example).  So If I understand you
>>>> correctly then something like this -
>>>>> --the first select gives you those records in both tables your 25 udokai
>>>>>  UNION
>>>>>  UNION
>>>>>  SELECT nul As field1, null As field2, kai.field3, kai.field4,
>>>>> Unioned together you should get
>>>>> 25 + 15 + 40 = ? 80
>>>>> Hope that helps,
>>>>> Regina
>>>> UFF - that seems to be a complex question, a comprehensive operation and
>>>> a lot to type too!!! Thanks a million - i would have spent many time to
>>>> find out this query by myself! Ok..... how can i perform your "UNION": I
>>>> would just insert my selects one after another in one new table - will
>>>> that work well?
>>>> I want to aggregate around 20 datasets this way!? Do you know a method
>>>> to operate with more datasets (for example 7) in a effektiv manner and
>>>> not to do this three selects 6 times?
>>>> AND: Am i totally wrong with my aims? It seems to me that is an exotic
>>>> think to do with PostGis, but our projects/problems require to aggregate
>>>> datasets in almost all cases (around 90%) and that is exactly what one
>>>> of the basic functions "Union" in ArcView already carried out ten years
>>>> ago. So i would exspect there is a function to perform this operation
>>>> easier!? .....i just wonder.....
>>>> cheers      Andreas
>>>> Andreas Laggner
>>>>> Sent: Tuesday, August 28, 2007 7:28 AM
>>>>>> BASIC TRICK:  If you want to get all records with no matching
>>>> including those that match - put what you would normally put in your
>>>> WHERE clause in the JOIN clause and use a LEFT JOIN.
>>>>> ok - it seems to me i need some coaching......Yes, I want to get all
>>>>> records with no matching including those that match, but i also want to
>>>>> dissect the polygons that matches. I will try to explain again just to
>>>>> be sure you understood my aims: I have 20 polygons in udo and 50 in kai.
>>>>> 10 from kai are intersecting 5 from udo to 25 new polygons i call udokai
>>>>> (because they have attributes from udo AND kai). My result should have:
>>>>> 15 polygons with attributes only from udo, 40 polygons with attributes
>>>>> only from kai AND 25 with attributes from udo and kai! In most cases i
>>>>> want to do such a operation because i want to aggregate (spatial
>>>>> correct) different datasets!
>>>>> Which example from you fits best for this aim? I did not find any
>>>>> information on how left join works on the postgis or postgresql
>>>> reference...
>>>>>> Unfortunately as I have come across before if you need an either or
>>>> (if in table 1 or table 2 - ideally you would use a FULL JOIN but for
>>>> some reason Postgres chokes when you use postgis functions in the FULL
>>>> JOIN clause for the cases I have tried).  In that case you need a
>>>> workaround using a set of UNIONS.
>>>>>> Simplest case - get all records in g1 one or union of g1 and g2
>>>> that intersect
>>>>>> NOTE: COALESCE is an ANSI SQL function that will return the first
>>>> non-null - when you do a geomunion of a geometry and null you get null
>>>> which is why we need COALESCE
>>>>>> SELECT g1.field1, g1.field2, COALESCE(geomunion(g1.the_geom,
>>>> g2.the_geom), g1.the_geom) AS newgeom
>>>>>> FROM g1 LEFT JOIN g2 ON (g1.the_geom && g2.the_geom AND
>>>> intersects(g1.the_geom, g2.the_geom))
>>>>>> Either of case - get all geometries in g1 or g2 or union if there
>>>> is a match - workaround for full joins not working right
>>>>>> SELECT g1.field1, g1.field2, geomunion(g1.the_geom, g2.the_geom) AS
>>>> newgeom
>>>>>> FROM g1 INNER JOIN g2 ON (g1.the_geom && g2.the_geom AND
>>>>>> UNION
>>>>>> SELECT g1.field1, g1.field2, g1.the_geom AS newgeom
>>>>>> WHERE g2.the_geom IS NULL
>>>>>> UNION
>>>>>> SELECT g1.field1, g1.field2, g2.the_geom AS newgeom
>>>>>> FROM g2 LEFT JOIN g1 ON (g1.the_geom && g2.the_geom AND
>>>>>> WHERE g1.the_geom IS NULL
>>>>>> Hope that helps,
>>>>>> Regina
>>>> Andreas Laggner
>>>>>> Sent: Thursday, August 23, 2007 11:32 AM
>>>>>>> Oh the g1 g2 .. was just for example - I don't actually call my
>>>> tables meaningless names like that.
>>>>>>> You should be doing a join on something or have a where clause
>>>> unless one of your tables has only one record.  Otherwise you are
>>>> doing what is called a CROSS JOIN (cartesian product)  which gives you
>>>> an nxm records where n is the number of records in your first table
>>>> and m is the number in second table.  This is generally a big NO NO.
>>>> In certain rare cases you do want to do something like that, but is
>>>> usually the exception.
>>>>>> I think the records in my targed table must be added (more or less) and
>>>>>> not multiplied! My Aim is a table that contains the areas of all the 7
>>>>>> sourcetables and the information which refuges are inside and wich not.
>>>>>> Perhaps i must use the intersection!? If i do my query with a gist like
>>>>>> this: where t1.the_geom && t2.the_geom; than the operation is very fast
>>>>>> (about one minute) but i only have the Polygons covered by BOTH
>>>>>> datasets, and i want to have as well those, which are covered by one
>>>>>> dataset only!! But my operation without the where clause runs for 4
>>>>>> hours now - that shows me there is something wrong  ;-)
>>>>>>> Its hard for me to tell if you need a cartesian product in this
>>>> case since I'm not quite sure what for example nature and biosphere
>>>> represent.  I would guess that is wrong and you should first figure
>>>> out which sets of say nature records you need to geomunion with
>>>> biosphere and then join by that field or set of fields.
>>>>>>> It would help a bit if you could provide some sample questions you
>>>> expect to answer with your statistical analysis.  My guess is you may
>>>> be better off with more than one table.
>>>>>> Sample question: give me all areas (all polygons) from germany where
>>>>>> landuse=arable land and soils=good and precipitation>600 and any (of 7)
>>>>>> reserves and so on.......
>>>>>> I need the values in my table to calculate the potential yield or other
>>>>>> things...
>>>>>> And i want to analyse such questions with a statistical software (SAS),
>>>>>> so it seems to me i need one table to import in SAS (or to query from
>>>>>> SAS directly to the postgresql).
>>>>>> Thanks for your help, i will be back in my office in
>>>> Monday.......Andreas
>>>>>>> Which structure is best really boils down to what questions you
>>>> hope to answer because one approach may make one question easy and
>>>> fast and another question slow and cumbersome.
>>>>>>> Hope that helps,
>>>>>>> Regina
>>>> Andreas Laggner
>>>>>>> Sent: Thursday, August 23, 2007 10:04 AM
>>>>>>>> Andreas,
>>>>>>>> It would help to know what your table structure looks like and
>>>> why do you want to put them all in a single geometry?
>>>>>>> My table structures are a little bit different. I want to have
>>>> them in a
>>>>>>> single geometry to intersect them with other data and built a large
>>>>>>> table to run statistics over it (production site analysis over
>>>> germany).
>>>>>>>> I'm imaging you are you doing something like
>>>>>>>> SELECT g1.somefield, geomunion(geomunion(g1.the_geom,
>>>> g2.the_geom), g3.the_geom)
>>>>>>>> FROM g1 INNER JOIN g2 on g1.somefield = g2.somefield INNER JOIN
>>>> g3 on g2.somefield = g3.somefield
>>>>>>>> GROUP BY g1.somefield
>>>>>>> That´s an interesting method with inner join..why go you call your
>>>>>>> tables g1. g2. and so on?
>>>>>>> That´s my method i am using right now (geomunion 1 to 3 from 6), seems
>>>>>>> to be a pedestrian method :-(
>>>>>>>     (ffh_name character varying(80), ffh_land character
>>>> varying(3), ffh
>>>>>>> smallint, ffh_id smallint,
>>>>>>>      spa_name character varying(80), spa_land character
>>>> varying(3), spa
>>>>>>> smallint, spa_id smallint) with oids;
>>>>>>> select
>>>> addgeometrycolumn('','natura2000','the_geom','31467','MULTIPOLYGON',2);
>>>>>>> alter table natura2000 drop constraint enforce_geotype_the_geom;
>>>>>>>     select
>>>> t1.ffh_name,t1.ffh_land,t1.ffh,t1.ffh_id,t2.spa_name,t2.spa_land,t2.spa,t2.spa_id,
>>>>>>>             geomunion(t1.the_geom, t2.the_geom)
>>>>>>>             from ffh_rep t1, spa_rep t2;
>>>>>>> create table sg71
>>>> varying(3), ffh
>>>> varying(3), spa
>>>>>>> smallint, spa_id smallint,
>>>>>>>      bio_name character varying(70), bio smallint, bio_id
>>>> smallint) with
>>>>>>> oids;
>>>>>>> select
>>>> addgeometrycolumn('','sg71','the_geom','31467','MULTIPOLYGON',2);
>>>>>>> alter table sg71 drop constraint enforce_geotype_the_geom;
>>>>>>> insert into sg71
>>>>>>>     select t1.ffh_name, t1.ffh_land, t1.ffh, t1.ffh_id, t1.spa_name,
>>>>>>> t1.spa_land, t1.spa, t1.spa_id,
>>>>>>>             t2.name,t2.bio,t2.bio_id,geomunion(t1.the_geom,
>>>> t2.the_geom)
>>>>>>>             from natura2000 t1, biosphere t2;
>>>>>>> create table sg72
>>>>>>>        (ffh_name character varying(80), ffh_land character varying(3),
>>>>>>> ffh smallint, ffh_id smallint,
>>>>>>>     spa_name character varying(80), spa_land character varying(3), spa
>>>>>>>     bio_name character varying(70), bio smallint, bio_id smallint,
>>>>>>>     np_name character varying(60), np smallint, np_id smallint)
>>>> with oids;
>>>>>>> select
>>>> addgeometrycolumn('','sg72','the_geom','31467','MULTIPOLYGON',2);
>>>>>>> alter table sg72 drop constraint enforce_geotype_the_geom;
>>>>>>> insert into sg72
>>>>>>>             t1.bio_name,t1.bio,t1.bio_id,t2.np_name,t2.np,t2.np_id,
>>>>>>>             from sg71 t1, np t2;
>>>>>>> AND SO ON......
>>>>>>>> or
>>>>>>>> SELECT g1.somefield, geomunion(gt.the_geom)
>>>>>>>> FROM (SELECT somefield, the_geom FROM g1 UNION SELECT somefield,
>>>> the_geom FROM g2 ...) gt
>>>>>>>> GROUP BY gt.somefield
>>>>>>>> If I have 7 different tables that have pretty much the same
>>>> structure, but for logistical or other technical reasons (such as each
>>>> has additional attributes distinct from one another), I need to keep
>>>> them as separate tables, then I usually use inherited tables for that.
>>>> That way when I need to join all datasets at once, I can simply query
>>>> the parent table and it will automatically drill down to the child
>>>> tables. Not sure if that helps more than it confuses your situation.
>>>>>>>> Then instead of the above I can simply do
>>>>>>>> SELEG myparenttable.somefield, geomunion(myparenttable.the_geom)
>>>>>>>> FROM myparenttable
>>>>>>>> GROUP by gh.somefield
>>>>>>> ok - i have to think about your suggestions......that´s my second week
>>>>>>> with postgis.
>>>>>>> Can you tell me from my SQL-Statements which method will be best? So i
>>>>>>> try to understand that one.....
>>>>>>> Thanks for your reply!!!
>>>>>>>> Hope that helps,
>>>>>>>> Regina
>>>> Andreas Laggner
>>>>>>>> Sent: Thursday, August 23, 2007 9:11 AM
>>>>>>>> To: PostGis_Mailinglist
>>>>>>>> Subject: [postgis-users] Union of 7 datasets
>>>>>>>> Hi users,
>>>>>>>> i want to put together 7 datasets to have all the different
>>>> refuges in
>>>>>>>> one table (and in one geometry). Am i doing right with 6 times
>>>> geomunion
>>>>>>>> (that´s much to type with all the attributes) or is there a more
>>>>>>>> effective way?
>>>>>>>> cheers Andreas
>>>> Dipl. Geoökologe Andreas Laggner
>>>> Institut für Ländliche Räume (LR)
>>>> Bundesforschungsanstalt für Landwirtschaft (FAL)
>>>> Institute of Rural Studies
>>>> Federal Agricultural Research Centre (FAL)
>>>> Bundesallee 50
>>>> D-38116 Braunschweig
>>>> Tel.: (+49) (0)531 596 5515
>>>> Fax: (+49) (0)531 596 5599
>>>> E-mail: andreas.laggner at fal.de
>>>> Homepage: http://www.lr.fal.de/
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> *The substance of this message, including any attachments, may be
>>>> confidential, legally privileged and/or exempt from disclosure
>>>> pursuant to Massachusetts law. It is intended solely for the
>>>> addressee. If you received this in error, please contact the sender
>>>> and delete the material from any computer. *
Bundesallee 50
