[postgis-users] Re: PostGis reports
David William Bitner david.bitner at gmail.com
Thu Oct 4 08:24:54 PDT 2007
Gus,
Using I use MapServer to generate either a png or a jpg at a resolution of
150 or 300dpi and then embed that into the pdf using FPDF, I do not bother
with the pdf output format with MapServer.
David
On 10/2/07, Gustavo Ces <g.ces at pettra.es> wrote:
>  Hi David,
>     First of all, thanks for answering. I´ve got a question. I´ve read the
> FPDF user manual and it seems you only can add jpg or png images to your
> documents. How can you link the PDF with mapserver? Does this serve jpg
> images ( as geoserver, for instance) or is it an aplication and FPDF only
> interprets it as a confuse string?
> Gus
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071004/802633ed/attachment.html>
