[postgis-users] simplify crashing postgres on larger table
ivan minčík
ivan.mincik at gmail.com
Tue Oct 16 06:18:35 PDT 2007
I tried to compile the newest version of postgis, but the result is the
same. I am going to start looking for that wrong geometry
Paul Ramsey wrote:
> Where I used 'sizeof' I meant 'mem_size'...
> On 15-Oct-07, at 2:36 PM, Paul Ramsey wrote:
>> Well, you have a bug in your sights, probably, but you haven't
>> isolated it...
>> First, is it the UPDATE or the function?
>> Does
>> SELECT sizeof(simplify(the_geom,500)) FROM thetable
>> crash the backend?
>> If it's the function, then, it's either the number of features and
>> bad luck with a memory leak, or a single geometry that crashes the
>> function. Find out if it's the geometry by repeatedly dividing your
>> data set into halves and checking each half separately. If one half
>> keeps failing, you'll eventually winnow it down to the offending
>> geometry, and you can report that back here and the fix should be
>> "easy".
>> P.
>> On 15-Oct-07, at 12:17 PM, ivan minčík wrote:
>>> Halo postgis users,
>>> I found that this query:
>>> UPDATE table SET the_geom500=simplify(the_geom,500);
>>> is crashing postgres database on 2 GB table. On smaller table
>>> everything is OK.
>>> I have tested this on 2 Debian Etch stable computers (postgresql and
>>> postgis from repositories).
>>> after some 5 minutes I always get
>>> server closed the connection unexpectedly
>>> This probably means the server terminated abnormally
>>> before or while processing the request.
>>> The connection to the server was lost. Attempting reset: Failed.
>>> in log there is
>>> 2007-10-15 21:08:47 CEST LOG: server process (PID 5234) was
>>> terminated by signal 11
>>> 2007-10-15 21:08:47 CEST LOG: terminating any other active server
>>> processes
>>> 2007-10-15 21:08:47 CEST LOG: all server processes terminated;
>>> reinitializing
>>> 2007-10-15 21:08:47 CEST FATAL: the database system is starting up
>>> 2007-10-15 21:08:47 CEST LOG: database system was interrupted at
>>> 2007-10-15 21:08:40 CEST
>>> 2007-10-15 21:08:47 CEST LOG: checkpoint record is at 1/5BCE111C
>>> 2007-10-15 21:08:47 CEST LOG: redo record is at 1/5B546840; undo
>>> record is at 0/0; shutdown FALSE
>>> 2007-10-15 21:08:47 CEST LOG: next transaction ID: 45777; next OID:
>>> 131584
>>> 2007-10-15 21:08:47 CEST LOG: next MultiXactId: 1; next
>>> MultiXactOffset: 0
>>> 2007-10-15 21:08:47 CEST LOG: database system was not properly shut
>>> down; automatic recovery in progress
>>> 2007-10-15 21:08:47 CEST LOG: redo starts at 1/5B546840
>>> 2007-10-15 21:08:50 CEST LOG: invalid magic number 0000 in log file
>>> 1, segment 98, offset 15826944
>>> 2007-10-15 21:08:50 CEST LOG: redo done at 1/62F17F90
>>> 2007-10-15 21:08:55 CEST LOG: database system is ready
>>> 2007-10-15 21:08:55 CEST LOG: transaction ID wrap limit is
>>> 2147484146, limited by database "postgres"
>>> Does anybody knows what is going on?
>>> thanks Ivan
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
