[postgis-users] loci of points
Michael Welter
mike at telecommatters.net
Wed Oct 17 07:32:13 PDT 2007
What I need to do is divide a group of geographic points into <n>
clusters such that the convex hulls of each cluster do not overlap.
Each cluster would have approximately the same number of points, and the
perimeter of each cluster would be minimized.
This is the Traveling Salesman Problem, only there are <n> salesmen.
The problem is how to determine the "territory" for each salesman in
order to minimize travel costs.
Thanks
Stephen Woodbridge wrote:
> Michael Welter wrote:
>> Is there an algorithm to divide a group of points into <n> distinct
>> groups?
> A locus is a set of points satisfying a certain condition.
> So what are you conditions?
> There are a lot of ways an arbitrary grouping can be made from a larger
> set. What should determine if any given point should belong to group 1
> or 2 or N?
> It is hard to solve a problem that is under defined, unless one makes up
> arbitrary constraints to satisfy the problem.
> -Steve W.
> postgis-users mailing list
Michael Welter
Telecom Matters Corp.
Denver, Colorado US
+1.303.414.4980
mike at TelecomMatters.net
www.TelecomMatters.net
