[postgis-users] detect poly's with duplicated vertex
Rob Agar
robagar at westnet.com.au
Sat Oct 20 23:42:46 PDT 2007
perfect, thanks Kevin.
Kevin Neufeld wrote:
> Try using ST_SnapToGrid(geometry, size) will remove coincident points.
> To identify polygons with dups,
> SELECT *
> FROM mypolytable
> WHERE ST_NPoints(geom) != ST_NPoints(ST_SnapToGrid(geom, <some
> precision>));
> -- Kevin
> Rob Agar wrote:
>> hi all,
>> Another quick question - is there a function for detecting polygons
>> with one or more sequential duplicated points? Basically, I want to
>> find and replace polys like "abccd" with "abcd".
>> cheers
>> Rob
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
