[postgis-users] noding problem
Obe, Regina
robe.dnd at cityofboston.gov
Thu Oct 25 04:24:45 PDT 2007
Interesting - I was expecting st_distance() to perform a bit better than
intersects (but then on second thinking I realized maybe not).
It seems to me that all st_intersects has to do is find one point shared
by the 2 geometries and it can declare victory plus I imagine that there
are certain higher rules of topology it has at its disposal that make
the order of searching of points a bit more efficient than st_distance.
On the downside there is also the issue that st_intersects will throw an
error if you feed it some invalid geometries whereas st_distance will
not.
st_distance except in the special case (where distance is 0) has to
basically verify that there is no point that has a distance lower than
the last lowest it checked. I'm sure there are some short-cuts here
without going deep into topology land, but I suspect fewer short-cuts
and that is the cause for its poorer perfomance when dealing with more
complex geometries.
Am I safe in saying that distance treats the case of distance() == 0 as
a special case - e.g. you can't get lower than 0 for distance so there
is no point in checking any further?
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Kevin Neufeld
Sent: Wednesday, October 24, 2007 7:45 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] noding problem
Well, there you have it. Thanx for pointing that out Chris. Goes to
show that there often many ways to accomplish the same thing in
PostGIS. I suppose it also really depends on the geometries (size,
type, etc). For the type of queries I often perform, checking distance
is sometimes faster than computing intersects(). This obviously isn't
the case for you. Good work. Glad to hear you're making progress.
For my own curiosity I timed a few similar queries as yours.
For two sets of ~3000 polygons,
using intersects() is significantly faster.
For two sets of ~5000 linestrings
using intersects() is 1.5 times faster.
For a set of ~300000 linestrings and ~300000 points
using distance()==0 is 1.5 times faster.
For a set of ~17000 polygons and 33000 points
using distance()==0 is 1.9 times faster.
Cheers,
Kevin
Chris Hermansen wrote:
> Kevin makes some suggestions as to why I have empty geometry
collections
> and what is the quickest way to get rid of them. Based on his advice,
I
> thought I'd report some potentially useful info back to the list.
> I have 11,228 polygons in "fc" and 4553 polygons in "results". I have
a
> late-model Core2 Duo based Dell running Ubuntu 7.04. This is
> postgis1.3.1 and geos3.0.0RC4.
> I have three test versions of a select statement that delivers the
> intersection of "fc" and "results":
> 1. create temp table step1a as
> select
map,standid,opening_id,intersection(fc.the_geom,results.the_geom)
> as the_geom
> from fc,results
> where fc.the_geom && results.the_geom;
> which takes 28.113 seconds on my machine
> 2. create temp table step1a as
> select
> as the_geom
> from fc,results
> and st_distance(fc.the_geom,results.the_geom) = 0.0;
> which takes 4 minutes 5.903 seconds on my machine
> 3. create temp table step1a as
> select
> as the_geom
> from fc,results
> where st_intersects(fc.the_geom,results.the_geom);
> which takes 26.203 seconds on my machine
> Versions 2 and 3 both eliminate the empty geometry collections.
> Kevin mentions (see below) that version 2 might be the fastest, but at
> least in my case it is in fact the slowest of the bunch.
> I hope the list readers find this useful!
> Kevin, thanks a bunch for getting me on the right track!!!
>>> If I execute:
>>> select geometryType(st_intersection(pblk.geom,pvri.geom))
>>> from pblk,pvri
>>> where pblk.geom && pvri.geom;
>>> I get something quite different than what I expect. I expect to get
>>> polygons, and sometimes multipolygons - which I assume arise when
the
>>> intersection process splits up polygons into several constituent
parts.
>>> But I also get a bunch of geometrycollections. And these
>>> geometrycollections are apparently empty, for example, the first few
>>> lines of output from the above select:
>>> numgeometries | geometrytype
>>> | POLYGON
>>> | POLYGON
>>> 0 | GEOMETRYCOLLECTION
>>> | POLYGON
>>> Are these supposed to be there? What conceivable purpose could they
>>> serve?
>> Hi Chris,
>> Consider the cases where geometry bounding boxes intersect but the
>> geometries do not. In these cases, the intersection will be empty.
>> You probably want to add an additional filter to your query. "WHERE
>> pblk.geom && pvri.geom AND distance(pblk.geom, pvri.geom) = 0". (You
>> could alternatively use intersects(geometry, geoemetry), but
>> distance==0 is faster).
>> Does this help?
>> -- Kevin
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
