[postgis-users] bow-tie polygons and the like
Martin Davis
mbdavis at refractions.net
Tue Apr 1 13:24:26 PDT 2008
Chris,
Can you post the WKT for the problematic feature? (Ascii art is nifty,
but not really a substitute for a 1600x1200 pixel display... 8^)
Chris Hermansen wrote:
> Hi Nicolas, all;
> Nicolas, I understand your comment. But after looking at the data some
> more in OpenJump, that appears to not be my problem.
> If I load the PostGIS theme into OpenJump and run the QA on it, I see
> that it is the polygon that contains the bow-tie shaped figure that is
> the problem.
> I can represent this schematically as:
> (again, I hope this works out visually. I have done the figure in
> fixed-width text).
> OpenJump's QA tool shows that there is an error in the enclosing polygon
> at the "bow-tie point", and that the enclosing polygon is a bad feature.
> The triangle polygons themselves are not shown as bad features. There
> are points shown at all corners of the triangles, ie there is no real
> "bow-tie" type self intersection.
> The enclosing polygon contains all the edges shown in the above figure,
> including those of the triangles. Each triangle is a separate polygon.
> I've traced the order of the edges of the enclosing polygon and it
> appears that it is the ordering of these edges that is creating the
> crossing / bow-tie in the enclosing polygon. That is, the enclosing
> polygon's points define the edges as follows:
> pt 0: se corner of east triangle
> pt 1: bow-tie point
> pt 2: nw corner of west triangle
> pt 3: sw corner of west triangle
> pt 4: bow-tie point
> pt 5: ne corner of east triangle
> ... and off to the remainder of the enclosing polygon points
> So it appears to me that the edges of the western triangle are actually
> traversed in the wrong order in the enclosing polygon. As well, clearly
> there is a self-intersection in the enclosing polygon.
> I conclude from this that the order of traversal of the western triangle
> edges could be reversed and preserve the clockwise traversal of the
> enclosing polygon's edges. However I think the fact that the bow-tie
> point is traversed twice in the same polygon is a real problem that must
> be repaired (manually in this case, I guess).
> Does anyone have any comments on this? Thanks in advance!
> Nicolas Ribot wrote:
>>> Good people;
>>> I have this odd problem that I hope others may clarify for me.
>>> I have a big ArcInfo polygon coverage produced by a sequence of spatial
>>> unions. One of the component polygon coverages was brutalized somewhere
>>> along the way and it has some polygons with triangular and bow-tie
>>> inclusions.
>>> Nevertheless, the coverage is clean and sober as far as ArcInfo is
>>> concerned.
>>> If you all can picture in your minds a bow-tie polygon |><| where the
>>> rightmost | of the bowtie is actually the edge of an enclosing polygon, kind
>>> of like:
>>> (I sure hope that works out visually...)
>>> OK, when I use ogr2ogr to import this coverage into postgis 1.3.1 /
>>> geos-3.0.0rc4, I see the following:
>>> the containing polygon fails at st_isValid()
>>> the st_area() of the containing polygon appears to include the area of the
>>> bow-tie polygon, ie it is larger than the area copied over from the ArcInfo
>>> coverage by about the same amount as the area of the bow-tie polygon When I
>>> look at this little mess with OpenJump, sure enough the QA routines find the
>>> bow-tie and complain.
>>> The long and the short of this is that PostGIS returns slightly more area
>>> than ArcInfo does for the same big ugly polygon coverage, because of the
>>> apparent loss of these bow ties.
>>> What I'm not sure about is what exactly is wrong here. Is the bow-tie
>>> shape itself illegal? Or is it the fact that both sides of the bow-tie
>>> belong to the same polygon? Or something else I'm missing?
>>> Thanks for any light anyone can shed on this.
>> Hi,
>> I will only give a partial answer:
>> yes, a bowtie polygon is invalid for PostGIS (as stated in the OGC
>> SFSQL documentation, polygon's boundary cannot cross itself).
>> If you want to represent this with valid polygons, you will need 2
>> triangles touching at one point.
>> HTH
>> nicolas
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
