[postgis-users] Invoking GIST index on 2 disjoints within a query
Paul Ramsey
pramsey at cleverelephant.ca
Thu Apr 3 14:23:27 PDT 2008
Drop the &&. The indexes are not much help for testing Disjoint, unfortunately.
The other thing you could do is re-cast it as a does-not-intersect
test instead...
SELECT <some stuff> FROM A, B, C WHERE NOT ( ST_Intersects(A.the_geom,
B.the_geom) OR ST_Intersects(A.the_geom, C.the_geom) );
(The above will be indexed automatically for recent versions of
PostGIS. For older, add in the && clause manually like this.)
SELECT <some stuff> FROM A, B, C WHERE NOT ( (A.the_geom && B.the_geom
AND Intersects(A.the_geom, B.the_geom)) OR (A.the_geom && c.the_geom
AND ST_Intersects(A.the_geom, C.the_geom) ) );
YMMV... the B and C tables might be interacting and blowing up the
query, I don't have an intuitive feel for this stuff like Regina :)
P.
On Thu, Apr 3, 2008 at 2:12 PM, Dylan Lorimer <edylan at google.com> wrote:
> Hi,
> So I have probably a simple question but I don't use PostGIS enough to
> know the right way to go about this. Hoping someone can help.
> So I've got 3 spatial tables, each containing a bunch of polygon
> geometries. Let's call the tables A, B, C. What I want is to find out
> which polygons in table A are disjoint from all polygons in tables B
> and C. Meaning, which polygons in A have 0 overlap with polygons in B
> or C.
> I seem to have no troubles doing this when using only 2 tables, but
> adding the 3rd is messing things up. Oh, and I also want to invoke the
> GIST indexes to speed things up.
> Here's the (slightly generalized) query I think I should be using:
> SELECT <some stuff> FROM A, B, C WHERE disjoint(A.the_geom,
> B.the_geom) AND disjoint(A.the_geom, C.the_geom) AND <some other
> attribute filters> AND A.the_geom && B.the_geom AND A.the_geom &&
> C.the_geom;
> I've not seen this query complete successfully as it takes so long,
> but I think something is wrong with it as running it against only A
> and B is really quick and there aren't too many geometries in the
> tables.
> Thoughts?
> Cheers,
> dylan
> postgis-users mailing list
