[postgis-users] Cannot display postGIS layers on ms4w 4.6.1
Paragon Corporation lr at pcorp.us
Thu Apr 3 22:37:24 PDT 2008
Just a guess I think bata-admin as a schema is a bad choice of schema names.
I think you have to quote it if you are going to use that.  I would change
it to rename your schema if I were you.  To something like bata_admin
If you go with what you have, I think you may need to quote it and I'm not
even sure if that is legal in mapserver since I've never needed to quote my
schemas.
  LAYER
    NAME 'batas_administrasi_line2_utm'
    TYPE LINE
    CONNECTIONTYPE postgis
    CONNECTION 'host=localhost user=rtrw dbname=rtrw-pacitan-trenggalek'
    DATA 'the_geom FROM
"batas-admin".batas_administrasi_line2_utm'
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
kreshna_iceheart at yahoo.com
Sent: Friday, April 04, 2008 12:35 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Cannot display postGIS layers on ms4w 4.6.1
I'm trying to display postGIS layers on MapServer. I am using the following
components:
1) MapServer 4.6.1 for Windows (ms4w)
2) postgreSQL 8.2
3) shp2pgsql release 1.1.6
4) QuantumGIS 0.9.2 to automatically generate my mapfile
My mapfile is attached with this email. It only has a single layer (for
testing purpose), and it does not contain any complex query at all. The
layer definition is as follows:
  LAYER
    TYPE LINE
    DATA 'the_geom FROM
batas-admin.batas_administrasi_line2_utm'
Yet, when I tried to display the mapfile, I got the following error message:
msDrawMap(): Image handling error. Failed to draw layer named
'batas_administrasi_line2_utm'.
prepare_database(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text
from batas-admin.batas_administrasi_line2_utm WHERE () and (the_geom &&
setSRID( 'BOX3D(528656.510416667
9074209,609071.177083333
9134520)'::BOX3D,find_srid('','batas-admin.batas_administrasi_line2_utm','th
e_geom')
Postgresql reports the error as 'ERROR: syntax error at or near "-" at
character 116 '
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column name>
using SRID=<srid#>'
Make sure you put in the 'using unique <column name>'
and 'using SRID=#' clauses in.
For more help, please see
http://postgis.refractions.net/documentation.php
Mappostgis.c - version of Jan 23/2004.
I have tried the following solution:
(1) changing "FROM" to "from" (uppercase to lowercase)
(2) enabling oid in my database:
- uncommenting the line "default_with_oids" in my postgresql.on
- changing the value to "on"
- restarting posgresql
- re-creating all my postGIS tables
Yet none of the solution above work. MapServer just keeps giving me the
error message.
What happens? Anyone know a working solution?
Thanks,
-Kresh
____________________________________________________________________________
________
You rock. That's why Blockbuster's offering you one month of Blockbuster
Total Access, No Cost.
http://tc.deals.yahoo.com/tc/blockbuster/text5.com
So be it. If saying "NO" means being alone, then to hell with love, with
women, with marriage, with God, religions, bars, nightclubs, computer games,
and all the shit life keeps pumping at me. I'll walk alone, but with freedom
and a healed pride.
________
