[postgis-users] ERROR: Operation on mixed SRID geometries afterupgrading to recent postgres/postgis
Obe, Regina
robe.dnd at cityofboston.gov
Fri Apr 4 06:39:50 PDT 2008
This is a known issue which is fixed in the postgis-svn version. Use
that instead of 1.3.2. I think 1.3.3 will be out soon too that will
have the patch in it.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Sebastian Reitenbach
Sent: Friday, April 04, 2008 9:32 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] ERROR: Operation on mixed SRID geometries
Hi all,
I'm in the phase of evaluating an upgrade of postgres/postgis from
8.1.4/1.1.2 to 8.3.X/1.3.2.
But while testing, I ran into trouble with one of the queries that
worked
before
Now I have postgresql-8.3.1.tar.bz2 or postgresql-8.3.0.tar.bz2, and
proj-4.6.0.tar.gz, postgis-1.3.2.tar.gz, and geos-3.0.0.tar.bz2
installed.
With the old database/postgis version constellation (geos-2.2.2.tar.bz2,
postgis-1.1.2.tar.gz, proj-4.4.9.tar.gz, and postgresql-8.1.4.tar.bz2)
the
query below worked:
select "TILE_ID", innerst_shape
from
(select original_tile."UNIQUE_ID",
original_tile."TILE_ID",
original_tile."TILE_INTERIOR_SHAPE",
original_tile."TILE_POLY_SHAPE",
difference(original_tile."TILE_INTERIOR_SHAPE",
geomunion(intersect_tile."TILE_POLY_SHAPE")) as
innerst_shape
FROM "tile" original_tile
JOIN "tile" intersect_tile
ON (intersect_tile."TILE_ID"!= original_tile."TILE_ID" AND
intersect_tile."TILE_POLY_SHAPE" && original_tile."TILE_INTERIOR_SHAPE"
and
Intersects(intersect_tile."TILE_POLY_SHAPE",
original_tile."TILE_INTERIOR_SHAPE") and
round(intersect_tile."TILE_ID"/100000)<=round(original_tile."TILE_ID"/10
0000))
WHERE original_tile."TILE_ID" in
(select "TILE_ID"
from "tile"
where "TILE_POLY_SHAPE"&& GeomFromText('POLYGON((75.7491342
31.0239757,75.7473798 30.7984119,76.0086717 30.7966414,76.0110403
31.02219,75.7491342 31.0239757))', 4326) and
Intersects ("TILE_POLY_SHAPE", GeomFromText('POLYGON((75.7491342
31.02219,75.7491342 31.0239757))', 4326)) )
GROUP BY original_tile."UNIQUE_ID", original_tile."TILE_ID",
original_tile."TILE_POLY_SHAPE") as subquery
where
not IsEmpty(innerst_shape) and
Intersects(innerst_shape, GeomFromText('POLYGON((75.7491342
and not Touches(innerst_shape, GeomFromText('POLYGON((75.7491342
********** Error **********
SQL state: XX000
this worked with the old versin, without glitch.
So anybody has an idea what this error message mean, and more
importantly
how to overcome it?
kind regards
Sebastian
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
