[postgis-users] postgis mapfile php
Gabe
gabe at agtrix.com
Sun Apr 6 20:13:52 PDT 2008
There are two ways you can do that
$layer->set("data", "the_geom ....");
Or
$layer->setFilter("name = 'Greece'");
Hope that helps
Gabe
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of nickthegreek-
> Sent: Monday, 7 April 2008 10:46 AM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] postgis mapfile php
> stephen it worked that..may thanks.. do u have an answer also for the
> previous question??
> how could i change the where=greece in the mapfile
> with any country i select from a menu
> i try ..
> this_layer->set("Data","the...geom....... ");
> but it doesn't work
> View this message in context: http://www.nabble.com/postgis-mapfile-
> php-tp16530438p16531835.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
