[postgis-users] 1.3.3 Pre-Release Notice
Paragon Corporation
lr at pcorp.us
Tue Apr 8 23:10:21 PDT 2008
By the way I'm still testing out my DBF only feature to shp2pgsql in my
tiger load to make sure it works fully and I didn't break something in the
process. The change was sadly much more invasive than I had hoped. I ended
up having to touch a lot of functions in the shp2pgsql, so I guess it won't
be able to make it in for this release.
Would anyone be interested in testing it out? And How should I contribute
the code Paul since I'm a terrible newbie?
The change is as follows
1) If the shp2pgsql can't find a companion shp file, it will display a
warning that there is no shp file and that it will just do an attribute load
and skip creating the geometry column.
2) I also added another switch called n - which means don't load shape.
Not sure how useful this would be to people, but it is something that I have
needed off and own when I actually don't care about the geometry.
3) I also fixed some typos.
The other issue I noticed with the file, and could just be my editor (which
drove me a bit crazy) is that in some locations, the indentation is off so I
reindented some sections. Also less of a deal there seems to be a mix of
syntax style -e.g
if () {
Vs.
if (..)
What is the prefered style?
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, April 09, 2008 12:05 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] 1.3.3 Pre-Release Notice
Correct, I changed them all to strcmp(sr_id,"-1"), which should do the
trick.
On Tue, Apr 8, 2008 at 5:51 PM, Paragon Corporation <lr at pcorp.us> wrote:
> By the way I have been looking at that file and wrote up some code to
> deal with DBF only situations which I am still testing thru.
> For your info - all those lines contain sr_id && sr_id != "-1"
> And sr_id is initialized as
> char *sr_id =NULL
> I forgot all my C, but am I mistaken in saying that
> sr_id != "-1" is not a safe comparison since you are comparing
> address with a constanct string "-1"
> Hope that helps,
> Regina
> Paul Ramsey
> Sent: Tuesday, April 08, 2008 5:38 PM
> OK, they should be gone now... btw what compiler are you using, I
> didn't get those...
> On Tue, Apr 8, 2008 at 2:22 PM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk> wrote:
> > On Monday 07 April 2008 22:12:42 Paul Ramsey wrote:
> > > Folks,
> > > 1.3.3 is going to be coming out by the end of this week. If you
> > have > time, please pull the SVN version and give it a try, to
> ensure > we > haven't left any big bugs in the bin.
> > > Thanks!
> > > Paul
> > Here's something else we need to look at before release. I see the
> > following (rather scary) warnings when compiling shp2pgsql:
> > gcc -g -Wall -I.. -DUSE_ICONV -DUSE_VERSION=82
> > -DPOSTGIS_VERSION='"1.3.3SVN"' -c -o shp2pgsql.o shp2pgsql.c
> > shp2pgsql.c: In function 'InsertLineString':
> > shp2pgsql.c:786: warning: comparison with string literal results
> in > unspecified behaviour > shp2pgsql.c: In function
> 'InsertPolygon':
> > shp2pgsql.c:1069: warning: comparison with string literal results
> 'InsertPoint':
> > shp2pgsql.c:1205: warning: comparison with string literal results
> 'InsertMultiPoint':
> > shp2pgsql.c:1243: warning: comparison with string literal results
> in > unspecified behaviour > > I'm busy looking at GBT#13, so if
> anyone else would like to get to > this before I do, feel free.
> > ATB,
> > Mark.
> > Mark Cave-Ayland
> > Sirius Corporation - The Open Source Experts >
> http://www.siriusit.co.uk > T: +44 870 608 0063 > >
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
