[postgis-users] 1.3.3 Pre-Release Notice
Paul Ramsey
pramsey at cleverelephant.ca
Wed Apr 9 08:23:18 PDT 2008
> if ( sr_id && strcmp(sr_id,"-1") ) printf("SRID=%s;", sr_id);
> I have a very strong feeling that evaluation order in C is unspecified, rather
> than being from left to right; so for example the compiler could decide to
> generate code that evaluates the strcmp() first, in which case it would
> segfault on a NULL :( I think you would need to re-write something like this:
Should be fine: man -S7 operator
> if (sr_id)
> if (strcmp(sr_id,"-1") ) printf("SRID=%s;", sr_id);
> (looks even closer...)
> In fact, why is sr_id stored as a string anyway? We should make sr_id an
> integer with a default value of -1, and then use sscanf() within the switch()
> statement of pgis_getopt() to read its value.
I'll have a look at that, how is the estimated_extent investigation coming?
