[postgis-users] only insert valid/closed ring geometries
Shad Keene
shadkeene at hotmail.com
Thu Apr 10 10:34:13 PDT 2008
Thanks for the help...I'm using an if statement comparing the first and last coords as suggested earlier, and then a next if they are not equal. So far it works, but if I run into issues, I'll attempt the try catch block.
Shad
To: postgis-users at postgis.refractions.net
Subject: RE: [postgis-users] only insert valid/closed ring geometries
Date: Thu, 10 Apr 2008 12:24:01 -0400
For this kind of situation I usually use a Try Catch block and
then in the Catch either discard the error and move on or log
it.
I haven't used perl much, but from this, it looks like it supports
Try Catch
http://snippets.dzone.com/posts/show/928
Hope that helps,
Leo
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Shad
Keene
Sent: Thursday, April 10, 2008 9:36 AM
To:
Subject: [postgis-users] only
I started
using postgis recently because of the spatial capabilities, but I'm stuck
now.
I have a list of user-entered geometries that I'm inserting into a table via
perl. I'm using the following code to insert the geometries into the
table: (ISOL basically refers to a point
geometry.)
if ($cwa_entries[4] eq "AREA")
$sth = $dbh->prepare("INSERT into cwa
values(GeomFromText('POLYGON(($cwa_entries[3]))', 4326), '$cwa_entries[6]',
'$cwa_entries[5]', nextval('cwa_id_seq'), '$cwa_entries[0]',
'$cwa_entries[1]', '$cwa_entries[4]')") or die "could not execute:
$DBI::errstr";
elsif ($cwa_entries[4] eq "LINE") {
$sth
values(GeomFromText('LINESTRING($cwa_entries[3])', 4326), '$cwa_entries[6]',
$DBI::errstr";
elsif ($cwa_entries[4] eq "ISOL") {
$sth
values(GeomFromText('POINT($cwa_entries[3])', 4326), '$cwa_entries[6]',
$DBI::errstr";
$sth->execute() or die "Could
not execute: $DBI::errstr";
Sometimes there are values
that are entered that do not represent valid geometries. For instance, I
might get a set of coordinates that is designated a polygon, but the last
coordinates don't equal the first coordinates(i.e. non-closed ring). I
don't have any control over the data that reaches me(i.e. it's already
designated as AREA or LINE or ISOLD(for point). So how can I skip the
non-closed-ring geometries and only enter the valid geometries so that my
script doesn't quit on me and produce an error before it enters all the
data. Right now, I get an error on the execute statement, and it pretty
much prevents the rest of the data from being inserted into the
database. This may be a more perl-centered question, but I thought there
might be a postgresql command that has the effect of "insert only if
GeomFromText()...is valid", else move on to the next insert. I did see
the ST_IsClosed(geometry) and the ST_IsValid(geometry)
statements, but I don't know how to implement them prior to the insert.
Thanks for any help.
Shad
Get in touch in an instant. Get Windows Live Messenger now.
_________________________________________________________________
Going green? See the top 12 foods to eat organic.
http://green.msn.com/galleries/photos/photos.aspx?gid=164&ocid=T003MSN51N1653A
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080410/1c63e53b/attachment.html>
