[postgis-users] SQLite and postGIS
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Apr 11 15:55:07 PDT 2008
Ron M wrote:
> Stephen Woodbridge wrote:
>> Databases basically do not work over NFS mounted filesystems because
>> of locking and caching issues.
> Surely that's an exaggeration.
OK, it is a slight exaggeration, but unless you really know what you are
doing you just should stay away from it. I think the real issue is taht
while NFS works great for common file sharing and stuff and you really
don't have to know much about it that is just not the case if you are
trying to setup a database over it.
I think it is a case of "Buyer be ware!" or you might loose your data.
-Steve
> http://blogs.netapp.com/dave/2007/08/oracle-optimize.html
> "Oracle uses NFS to run its applications on tens of thousands
> of Linux servers accessing many petabytes of NetApp storage.
> In 2005 they had 12,000 Linux servers and 3 petabytes of NetApp
> storage. Today’s numbers aren’t public, but they are much larger."
> But yeah, it is tricky:
> http://www.sunmanagers.org/pipermail/summaries/2002-April/001278.html
> postgis-users mailing list
