[postgis-users] SQLite and postGIS
P Kishor
punk.kish at gmail.com
Sun Apr 13 08:38:41 PDT 2008
On 4/13/08, Richard Greenwood <richard.greenwood at gmail.com> wrote:
> On Fri, Apr 11, 2008 at 9:29 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > Puneet, Rich,
> > SQLite is already supported as a spatial database by OGR. The caveat
> > is that in GDAL 1.5 it is just using a text column with WKT geometries so
> > the spatial performance is not great.
> > To use this with MapServer you would use CONNECTIONTYPE OGR and the
> > CONNECTION string would be the path for the sqlite database. The
> > DATA statement should hold the table name be accessed.
> Totally cool!
> I used SpatiaLite (http://www.gaia-gis.it/spatialite/) LoadShapefile()
> function to import a shapefile into a SQLite db. The geometries are
> stored as BLOBs in a field named "geom" Then:
> sqlite> alter table ownership add column WKT_GEOMETRY;
> sqlite> update ownership set WKT_GEOMETRY=astext(geom);
> Getting MapServer to use the SQLite table was very easy. Recent
> versions of MS4W have SQLite support in GDAL. So simply adding
> CONNECTIONTYPE OGR
> CONNECTION "path/to/SQLite.db"
> gets MapServer drawing geometries from SQLite.
> I'm playing with a table containing about 15,000 polygons and
> performance is fine.
> Thanks Frank, for pointing me in the right direction.
> Rich
Two days ago I wrote --
> I am pretty confident
> that we shall see this ability sooner rather than later (a hunch,
> nonetheless, a confident hunch).
that was indeed sooner than even I expected.
Development with SQLite is just so easy that all other advantages that
other more complicated solutions may have just become less important.
Good going Rich.
Puneet.
