[postgis-users] RE: Speeding up SQLiteGIS
Martin Chapman mchapman at texelinc.com
Sun Apr 13 18:22:24 PDT 2008
Oh yeah, one more thing:
Add the following to the top of your
\GDAL\ogr\ogrsf_frmts\sqlite\ogrsqlitedatasource.cpp class under " #include
"cpl_string.h":
#include <algorithm>
using namespace std;
template<class T>
void replace(std::basic_string<T> &source, const std::basic_string<T> &find,
const std::basic_string<T> &replace)
	size_t j;
	for (;(j = source.find( find )) != std::basic_string<T>::npos;)
		source.replace(j, find.length(), replace);
template<class T>
void ltrim(std::basic_string<T> &s, const std::basic_string<T> &trimset)
    s.erase(0, s.find_first_not_of(trimset));
template<class T>
void rtrim(std::basic_string<T> &s, const std::basic_string<T> &trimset)
    s.resize(s.find_last_not_of(trimset) + 1);
template<class T>
void trim(std::basic_string<T> &s, const std::basic_string<T> &trimset)
    rtrim(s, trimset);
    ltrim(s, trimset);
Best regards,
Martin
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Martin
Chapman
Sent: Sunday, April 13, 2008 7:15 PM
To: punkish at eidesis.org
Cc: 'PostGIS Users Discussion'
Subject: [postgis-users] RE: Speeding up SQLiteGIS
Punkish,
I shared similar code last year for postgresql and mysql but it never made
it into the branch.
Here is the first change for the GetFeature() function of the sqllite
driver.  It is changed to use a new select statement (because no cursors in
sqlite).  I will pretty it up and send the final version later.
1.  replace OGRSQLiteSelectLayer def in
/GDAL/ogr/ogrsf_frmts/sqlite/ogr_sqlite.h
/*                         OGRSQLiteSelectLayer                         */
class OGRSQLiteSelectLayer : public OGRSQLiteLayer
	CPLString			m_sTableName;
  public:
                        OGRSQLiteSelectLayer( OGRSQLiteDataSource *,
                                              sqlite3_stmt * );
                        ~OGRSQLiteSelectLayer();
    virtual void        ResetReading();
    virtual int         GetFeatureCount( int );
    virtual OGRFeature *GetFeature( long nFeatureId );
    virtual int         TestCapability( const char * );
    virtual void	ClearStatement();
	virtual void	SetTableName(const char* pszTableName);
2.  Add the following block of code to
/GDAL/ogr/ogrsf_frmts/sqlite/ogrsqlitedatasource.cpp ExecuteSQL() method at
the end of the function just before the line " return poLayer;";
	std_string sSQLStatement = pszSQLCommand;
	std_string sTableName;
	transform(sSQLStatement.begin(), sSQLStatement.end(),
sSQLStatement.begin(), tolower);
	int n = (int) sSQLStatement.find("from");
	if (n != -1)
		sTableName = sSQLStatement.substr(n, sSQLStatement.length()
- n);
		replace(sTableName, std_string("from "), std_string(""));
		trim(sTableName, std_string(" "));
		trim(sTableName, std_string("'"));
		n = (int) sTableName.rfind("where");
		if (n != -1)
			sTableName = sTableName.substr(0, n);
		n = (int) sTableName.rfind("order by");
		if (n != -1)
		n = (int) sTableName.rfind("'");
		if (n != -1)
		else
			n = (int) sTableName.find(" ");
			if (n != -1)
		trim(sTableName, string(" "));
		poLayer->SetTableName(sTableName.c_str());
3.  The following code replaces the GetFeature() method in
GDAL/ogr/ogrsf_frmts/sqlite/ogrsqliteselectlayer.cpp file.
/*                          GetFeature()                           */
OGRFeature *OGRSQLiteSelectLayer::GetFeature( long nFeatureId )
	iNextShapeId = nFeatureId;
	CPLString osCommand;
	osCommand.Printf("SELECT * FROM %s WHERE OGC_FID = '%d' Limit 1",
m_sTableName.c_str(), iNextShapeId);
	sqlite3_stmt* hStmt = NULL;
	if (sqlite3_prepare(poDS->GetDB(), osCommand, (int)
osCommand.size(), &hStmt, NULL ) != SQLITE_OK)
		return NULL;
	int rc = sqlite3_step( hStmt );
	if( rc != SQLITE_ROW )
        ClearStatement();
        return NULL;
    int iField;
    OGRFeature *poFeature = new OGRFeature( poFeatureDefn );
    if( pszFIDColumn != NULL )
        int iFIDCol;
        for( iFIDCol = 0; iFIDCol < sqlite3_column_count(hStmt); iFIDCol++ )
            if( EQUAL(sqlite3_column_name(hStmt,iFIDCol),
                      pszFIDColumn) )
                break;
        if( iFIDCol == sqlite3_column_count(hStmt) )
            CPLError( CE_Failure, CPLE_AppDefined,
                      "Unable to find FID column '%s'.",
                      pszFIDColumn );
            return NULL;
        poFeature->SetFID( sqlite3_column_int( hStmt, iFIDCol ) );
    else
        poFeature->SetFID( iNextShapeId );
    iNextShapeId++;
    m_nFeaturesRead++;
    if( pszGeomColumn != NULL )
        int iGeomCol;
        for( iGeomCol = 0; iGeomCol < sqlite3_column_count(hStmt);
iGeomCol++ )
            if( EQUAL(sqlite3_column_name(hStmt,iGeomCol),
                      pszGeomColumn) )
                break;
        if( iGeomCol == sqlite3_column_count(hStmt) )
                      "Unable to find Geometry column '%s'.",
                      pszGeomColumn );
            return NULL;
        char *pszWKTCopy, *pszWKT = NULL;
        OGRGeometry *poGeometry = NULL;
        pszWKT = (char *) sqlite3_column_text( hStmt, iGeomCol );
        pszWKTCopy = pszWKT;
        if( OGRGeometryFactory::createFromWkt( &pszWKTCopy, NULL,
                                               &poGeometry ) == OGRERR_NONE
            poFeature->SetGeometryDirectly( poGeometry );
    for( iField = 0; iField < poFeatureDefn->GetFieldCount(); iField++ )
        OGRFieldDefn *poFieldDefn = poFeatureDefn->GetFieldDefn( iField );
        int iRawField = panFieldOrdinals[iField] - 1;
        if( sqlite3_column_type( hStmt, iRawField ) == SQLITE_NULL )
            continue;
        switch( poFieldDefn->GetType() )
        case OFTInteger:
            poFeature->SetField( iField,
                sqlite3_column_int( hStmt, iRawField ) );
            break;
        case OFTReal:
                sqlite3_column_double( hStmt, iRawField ) );
            break;
        case OFTBinary:
                const int nBytes = sqlite3_column_bytes( hStmt, iRawField );
                poFeature->SetField( iField, nBytes,
                    (GByte*)sqlite3_column_blob( hStmt, iRawField ) );
            break;
        case OFTString:
                (const char *)
                sqlite3_column_text( hStmt, iRawField ) );
            break;
        default:
            break;
#ifdef notdef
        int iField = poStmt->GetColId( pszGeomColumn );
        const char *pszGeomText = poStmt->GetColData( iField );
        OGRGeometry *poGeom = NULL;
        if( pszGeomText != NULL )
            OGRGeometryFactory::createFromWkt( (char **) &pszGeomText,
                                               NULL, &poGeom );
        if( poGeom != NULL )
            poFeature->SetGeometryDirectly( poGeom );
#endif
	if (hStmt)
		sqlite3_finalize(hStmt);
    return poFeature;
4.  Rebuild gdal.  Note that this change only optimizes the GetFeature(long
nFeatureId) method of a layer opened by a call to ExecuteSQL().  At least
random access calls are fast then.  I can also make the change in the
OGRSQLiteLayer and ogrsqlitetablelayer classes.  The function will always
work for random access calls because WHERE, ORDER BY and all other sql
clauses are irrelevant when accessing a row by ID.  Note that
GetNextFeature() will still be slow although we could speed up that function
as well.
ALSO here is the changes for MYSQL and POSTGRESQL for optimized random
access.
MYSQL:
/*                          GetFeature()                           */
OGRFeature *OGRMySQLResultLayer::GetFeature( long nFeatureId )
	iNextShapeId = bHasFid == TRUE ? nFeatureId - 1 : nFeatureId;
/*      Do we need to establish an initial query?                       */
    if( hResultSet == NULL )
        CPLAssert( pszQueryStatement != NULL );
        poDS->RequestLongResult( this );
        if( mysql_query( poDS->GetConn(), pszQueryStatement ) )
            poDS->ReportError( pszQueryStatement );
            return NULL;
        hResultSet = mysql_store_result( poDS->GetConn() );
            poDS->ReportError( "mysql_use_result() failed on query." );
            return FALSE;
/*      Fetch absolute record.
    char **papszRow = NULL;
    unsigned long *panLengths = NULL;
	OGRFeature *poFeature = NULL;
    if ( mysql_num_rows( hResultSet ) );
		mysql_data_seek( hResultSet, iNextShapeId );
		papszRow = mysql_fetch_row( hResultSet );
		if( !papszRow ) return NULL;
		panLengths = mysql_fetch_lengths( hResultSet );
		if ( !panLengths ) return NULL;
/*      Process record.                                                 */
		poFeature = RecordToFeature( papszRow, panLengths );
    return poFeature;
POSTGRESQL:
/*                             GetFeature()                             */
OGRFeature *OGRPGResultLayer::GetFeature( long nFeatureId )
	if (bHasFid == TRUE && nFeatureId < 1) return NULL;
	PGconn      *hPGConn = poDS->GetPGConn();
	if (hCursorResult != NULL)
		PQclear( hCursorResult );
		poDS->FlushSoftTransaction();
	poDS->SoftStartTransaction();
    osCommand.Printf( "DECLARE %s CURSOR for %s", pszCursorName,
    hCursorResult = PQexec(hPGConn, osCommand );
    osCommand.Printf( "FETCH ABSOLUTE %d in %s", nFeatureId, pszCursorName
    OGRFeature *poFeature = RecordToFeature( 0 );
    return poFeature;
Best regards,
Martin
Sent: Sunday, April 13, 2008 6:56 PM
To: Martin Chapman
Cc: PostGIS Users Discussion; Richard Greenwood; Stephen Woodbridge
Subject: Re: Speeding up SQLiteGIS
On 4/13/08, Martin Chapman <mchapman at texelinc.com> wrote:
> I'm working on it right now and will send you the code when I finish.
>  Basically SQLite is fast and the OGR code that uses sqlite is slow
because
>  of the way they wrote it.  My changes make OGR use random access versus
what
>  they do today and scroll from 0 to n for each record requested.  That
means
>  that row one will return quick but for each sub-sequent request the code
>  loops until it finds the record requested.  Very inefficient.  It has
speed
>  it up by about 50x on the very small shape file I am using to test.
Fantastic! Please consider sharing the code with Frank. He is the
ultimate custodian for OGR, and we want OGR itself to become better to
the extent that it can.
In the meantime, Frank, thanks yet again for making this possible (and
for help with the OGR syntax).
la la la (me happy again).
>  Best regards,
>  Martin
> From: P Kishor [mailto:punk.kish at gmail.com]
>  Sent: Sunday, April 13, 2008 6:41 PM
>  To: PostGIS Users Discussion
> Cc: Richard Greenwood; Stephen Woodbridge; Martin Chapman
>  Subject: Speeding up SQLiteGIS
>  (started a new thread)
>  > I can connect to SQLite using OGR in my application as seen in the
>  >  attachment.  It's kind of slow compared to shape but I can optimize
the
>  OGR
>  >  code for SQLite like I did for PostgreSQL and MySQL in my local copy
of
>  the
>  >  gdal code. Then it's as fast as shape.  I really like SQLite as well.
>  What
>  >  is the address of your WMS server?
>  Martin,
>  I am right now working on my laptop, but will soon put it on a
>  publicly accessible server. I am fooling around with a few tricks, and
>  now I am getting the entire table being selected *and* rendered in
>  about 92 ms. I think that is *very* good (this is a table of all the
>  zip code boundaries in the State of Wisconsin, US -- 1121 rows and all
>  the river segments -- > 183K rows).
>  Now, could you kindly share the "optimization" of OGR code *for*
>  SQLite? Have you considered submitted it back to Frank for possible
>  inclusion in the main branch?
>  Also, we could request OSGeo to set up some space for us to share
>  SQLite code, tricks, etc. In the meantime, I have bagged sqlitegis.org
>  and sqlitegis.com, and would be happy to host a wiki/list or whatever
>  crap the dreamhost allows me to host with a single-click install.
>  Seriously, this the first time in years that I have been excited by
>  all this mapping business. SQLite is just such an incredibly powerful
>  tool, not for its power and performance (which is plenty fast for me)
>  but for its incredible simplicity. The fasted program for me is the
>  one that allows me to install, setup and program the fastest.
>  >  Best regards,
>  >  Martin
>  >  [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of P
>  Kishor
>  >  Sent: Sunday, April 13, 2008 1:51 PM
>  >  To: PostGIS Users Discussion; Richard Greenwood
>  >  Subject: Re: [postgis-users] SQLite and postGIS
>  > On 4/13/08, Richard Greenwood <richard.greenwood at gmail.com> wrote:
>  >  > I should note that ogr2ogr creates a SQLite spatial table even more
>  >  >  easily that SpatiaLite:
>  >  >    ogr2ogr -f "SQLite" dest.db source.shp source
>  >  Thanks Rich. You made my day. I am drawing a layer with about 185K
>  >  rows, and, yes, there is a time lag, but this is out-of-the-box
>  >  performance.
>  >  One question -- the above ogr2ogr command, for me, does not seem to
>  >  cooperate when adding multiple shapefiles to the same db. If I do like
>  >  so
>  >  ogr2ogr -f "SQLite" dest.db source1.shp source2.shp source3.shp
>  >  I get a dest.db with 0 Kb. I got around that by creating dest1.db,
>  >  dest2.db and so on, and then creating dest.db, attaching the other
>  >  dbs, and moving the tables into dest.db via
>  >  CREATE TABLE ... AS SELECT * FROM....
>  >  This seems a bit goofy, so I am sure I am doing something wrong with
>  >  the ogr command. Suggestions?
>  >  Another note -- I wonder if this merits starting a separate SQLitegis
>  >  mailing list? I am happy here as long as the pg users don't mind.
>  >  >  Rich
>  >  >  On Sun, Apr 13, 2008 at 9:26 AM, Richard Greenwood
>  >  >  > On Fri, Apr 11, 2008 at 9:29 PM, Frank Warmerdam
>  <warmerdam at pobox.com>
>  >  wrote:
>  >  >  >  >  Puneet, Rich,
>  >  >  >  >  SQLite is already supported as a spatial database by OGR.
The
>  >  caveat
>  >  >  >  >  is that in GDAL 1.5 it is just using a text column with WKT
>  >  geometries so
>  >  >  >  >  the spatial performance is not great.
>  >  >  >  >  To use this with MapServer you would use CONNECTIONTYPE OGR
and
>  the
>  >  >  >  >  CONNECTION string would be the path for the sqlite database.
>  The
>  >  >  >  >  DATA statement should hold the table name be accessed.
>  >  >  >  Totally cool!
>  >  >  >  I used SpatiaLite (http://www.gaia-gis.it/spatialite/)
>  LoadShapefile()
>  >  >  >  function to import a shapefile into a SQLite db. The geometries
are
>  >  >  >  stored as BLOBs in a field named "geom" Then:
>  >  >  >    sqlite> alter table ownership add column WKT_GEOMETRY;
>  >  >  >    sqlite> update ownership set WKT_GEOMETRY=astext(geom);
>  >  >  >  Getting MapServer to use the SQLite table was very easy. Recent
>  >  >  >  versions of MS4W have SQLite support in GDAL. So simply adding
>  >  >  >    CONNECTIONTYPE OGR
>  >  >  >    CONNECTION "path/to/SQLite.db"
>  >  >  >  gets MapServer drawing geometries from SQLite.
>  >  >  >  I'm playing with a table containing about 15,000 polygons and
>  >  >  >  performance is fine.
>  >  >  >  Thanks Frank, for pointing me in the right direction.
>  >  >  >  Rich
>  Puneet Kishor http://punkish.eidesis.org/
>  Nelson Institute for Environmental Studies http://www.nelson.wisc.edu/
>  Open Source Geospatial Foundation (OSGeo) http://www.osgeo.org/
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
