[postgis-users] Re: Speeding up SQLiteGIS
P Kishor
punk.kish at gmail.com
Sun Apr 13 20:38:09 PDT 2008
Stephen,
On 4/13/08, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Martin Chapman wrote:
> > Stephen,
> > 1. You should use OGR in my opinion for a large list of reasons such as
> > comprehensive spatial projection support, format conversion support, quad
> > tree indexes and other features.
> Well I do not inherently have an objection to this, but I would prefer that
> my applications do not require GDAL/OGR as a dependency because that makes
> deploying them and order of magnitude more complicated with all the
> additional package dependencies.
Check out the instructions on extending SQLite with your own code. See
http://www.sqlite.org/cvstrac/wiki?p=LoadableExtensions (which is
really what the Spatialite guy has done)
Better yet, graft the OGR code into the SQLite amalgamation, and you
have a version of SQLite that is GDAL/OGR capable all within itself.
Build a DBD::SQLite with the above code, and you have the same within
a Perl module.
That way, a single DBD::SQLite installation (or just the single SQLite
library) becomes GDAL/OGR capable instead of depending on an external
library. The same could be done with the Proj.4 library.
> > 2. Yes there is a C and C++ API for OGR and GDAL. www.gdal.org See their
> > example page for where to start writing code. I would write a simple app
> > that uses OGR to access a SQLite database and read out all the geometries
> of
> > a table. You can also write the code to insert a shape file into SQLite.
> > See the source code for ogr2ogr.cpp to see how to do that. It comes with
> > GDAL.
> OK, I can look at this, I was just getting used to accessing SQLite from C
> and was hoping that we would add geometries, which we seem to have done, and
> spatial indexes.
> > 3. Not sure what you mean by "extended SQLite with GIS"? OGR is exactly
> > that if I understand you correctly. OGR can import\export shapefiles and
> > other vectors formats in\out of SQLite. In doing so it creates a geometry
> > column, handles insertion and extraction of OGC WKT geometries and other
> > issues when using geometry in a SQLite database. Use the program ogr2ogr
> to
> > insert a shape file into SQLite and then use a SQLite viewer to inspect
> the
> > contents of the table made by ogr2ogr. You will see what I mean. Without
> > OGR one would have to code all that stuff and it isn't trivial because you
> > need code to handle all types of OGC WKT geometries, etc.
> I'm thinking along the same lines as postGIS but in SQLite, so I can access
> it via C api and SQL. I think having support for SQLite in OGR is great. I
> use ogr2ogr on occasion and it is great for transforming data. I just don't
> understand the logic of why I have to use ogr C-api to get access to SQLite.
> It makes sense to load data through it, but for the same reasons I don't use
> OGR when I'm working in PostGIS, I would think that that would also apply to
> SQlite.
> > 4. Wiki is a really good idea. Maybe we can just use the GDAL wiki?
> > Frank, Farris Bueller, anyone?
> > 5. I think a good improvement to the SQLite OGR driver would be to add
> > spatial reference support. Currently, the OGR SQLite driver does not have
> > that support which limits it's functionality as a GIS storage system.
> Also,
> > OGR is only vector. I would imagine that storing geo-referenced imagery
> > would be useful as well. This would require adding a new driver for
> SQLite
> > to GDAL as an image provider. Do I hear "OSGEO summer of code" project?
> I'm not sure what you mean by add suport to the SQLite OGR driver. Why
> would you not add support to SQLite directly, and then it would be available
> to OGR, but also every other consumer of SQLite. LIKE:
> update spatialtable set the_geom = transform(the_geom, 26717);
> Yes, I'm sure OGR needs to be aware of what SQLite supports and have the
> driver modified to support that functionality.
> > What is it exactly that you guys want to create? I am using SQLite and
> OGR
> > for my viewer application but want to use it for a local geospatial
> catalog
> > system as well. I imagine a lot of what I do with it would be useful for
> > other purposes as well.
> I want to be able to build applications in C that use SQLite and are
> spatially enabled. I need to do queries like:
> select * from geomtable where st_distance(makepoint(x,y), the_geom) <
> 0.013;
> select * from geomtable where expand(makepoint(x,y), 0.013) && the_geom;
> where these queries would use a spatial index on the the_geom column.
> Best regards,
> -Stephen
> > Best regards,
> > Martin
> > -----Original Message-----
> > From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com] Sent: Sunday,
> April 13, 2008 9:02 PM
> > To: Martin Chapman
> > Cc: punkish at eidesis.org; 'PostGIS Users Discussion'; 'Richard Greenwood'
> > Subject: Re: Speeding up SQLiteGIS
> > OK, this is cool and evolving very quickly. So if I just want to write a C
> program using sqlite and GIS, where do I start.
> > Do I need to bring in GDAL/OGR now?
> > Is there a C-api for that?
> > Does this mean that no one is pursuing just extended SQLite with GIS?
> > Sorry, I'm getting lost here.
> > Punkish, I think setting up a wiki somewhere and post some examples would
> be very cool, and would be appreciated.
> > -Steve
> > > Punkish,
> > > I shared similar code last year for postgresql and mysql but it never
> made
> > > it into the branch.
> > > Here is the first change for the GetFeature() function of the sqllite
> > > driver. It is changed to use a new select statement (because no cursors
> > in
> > > sqlite). I will pretty it up and send the final version later.
> > > 1. replace OGRSQLiteSelectLayer def in
> > > /GDAL/ogr/ogrsf_frmts/sqlite/ogr_sqlite.h
> > > /* OGRSQLiteSelectLayer
> > > class OGRSQLiteSelectLayer : public OGRSQLiteLayer
> > > CPLString m_sTableName;
> > > public:
> > > OGRSQLiteSelectLayer( OGRSQLiteDataSource *,
> sqlite3_stmt * );
> > > ~OGRSQLiteSelectLayer();
> > > virtual void ResetReading();
> > > virtual int GetFeatureCount( int );
> > > virtual OGRFeature *GetFeature( long nFeatureId );
> > > virtual int TestCapability( const char * );
> > > virtual void ClearStatement();
> > > virtual void SetTableName(const char* pszTableName);
> > > 2. Add the following block of code to
> > > /GDAL/ogr/ogrsf_frmts/sqlite/ogrsqlitedatasource.cpp
> ExecuteSQL() method
> > at
> > > the end of the function just before the line " return poLayer;";
> > > std_string sSQLStatement = pszSQLCommand;
> > > std_string sTableName;
> > > transform(sSQLStatement.begin(),
> sSQLStatement.end(),
> > > sSQLStatement.begin(), tolower);
> > > int n = (int) sSQLStatement.find("from");
> > > if (n != -1)
> > > sTableName = sSQLStatement.substr(n,
> sSQLStatement.length()
> > > - n);
> > > replace(sTableName, std_string("from "), std_string(""));
> > > trim(sTableName, std_string(" "));
> > > trim(sTableName, std_string("'"));
> > > n = (int) sTableName.rfind("where");
> > > if (n != -1)
> > > sTableName = sTableName.substr(0, n);
> > > n = (int) sTableName.rfind("order by");
> > > if (n != -1)
> > > n = (int) sTableName.rfind("'");
> > > if (n != -1)
> > > else
> > > n = (int) sTableName.find(" ");
> > > if (n != -1)
> > > trim(sTableName, string(" "));
> poLayer->SetTableName(sTableName.c_str());
> > > 3. The following code replaces the GetFeature() method in
> > > GDAL/ogr/ogrsf_frmts/sqlite/ogrsqliteselectlayer.cpp
> file.
> > > /* GetFeature() */
> > > OGRFeature *OGRSQLiteSelectLayer::GetFeature( long
> nFeatureId )
> > > iNextShapeId = nFeatureId;
> > > CPLString osCommand;
> > > osCommand.Printf("SELECT * FROM %s WHERE OGC_FID = '%d' Limit 1",
> > > m_sTableName.c_str(), iNextShapeId);
> > > sqlite3_stmt* hStmt = NULL;
> > > if (sqlite3_prepare(poDS->GetDB(), osCommand, (int)
> > > osCommand.size(), &hStmt, NULL ) != SQLITE_OK)
> > > return NULL;
> > > int rc = sqlite3_step( hStmt );
> > > if( rc != SQLITE_ROW )
> > > ClearStatement();
> > > return NULL;
> > > int iField;
> > > OGRFeature *poFeature = new OGRFeature( poFeatureDefn );
> > > if( pszFIDColumn != NULL )
> > > int iFIDCol;
> > > for( iFIDCol = 0; iFIDCol < sqlite3_column_count(hStmt);
> iFIDCol++
> > > if(
> EQUAL(sqlite3_column_name(hStmt,iFIDCol),
> > > pszFIDColumn) )
> > > break;
> > > if( iFIDCol == sqlite3_column_count(hStmt) )
> > > CPLError( CE_Failure, CPLE_AppDefined,
> "Unable to find FID column '%s'.", pszFIDColumn );
> > > return NULL;
> > > poFeature->SetFID( sqlite3_column_int( hStmt, iFIDCol )
> > > else
> > > poFeature->SetFID( iNextShapeId );
> > > iNextShapeId++;
> > > m_nFeaturesRead++;
> > > if( pszGeomColumn != NULL )
> > > int iGeomCol;
> > > for( iGeomCol = 0; iGeomCol < sqlite3_column_count(hStmt);
> > > iGeomCol++ )
> > > if(
> EQUAL(sqlite3_column_name(hStmt,iGeomCol),
> > > pszGeomColumn) )
> > > break;
> > > if( iGeomCol == sqlite3_column_count(hStmt) )
> "Unable to find Geometry column '%s'.", pszGeomColumn
> > > return NULL;
> > > char *pszWKTCopy, *pszWKT = NULL;
> > > OGRGeometry *poGeometry = NULL;
> > > pszWKT = (char *) sqlite3_column_text( hStmt, iGeomCol );
> > > pszWKTCopy = pszWKT;
> > > if( OGRGeometryFactory::createFromWkt(
> &pszWKTCopy, NULL, &poGeometry
> > OGRERR_NONE
> > > poFeature->SetGeometryDirectly( poGeometry
> > > for( iField = 0; iField < poFeatureDefn->GetFieldCount(); iField++ )
> > > OGRFieldDefn *poFieldDefn = poFeatureDefn->GetFieldDefn( iField
> > > int iRawField = panFieldOrdinals[iField] - 1;
> > > if( sqlite3_column_type( hStmt, iRawField ) == SQLITE_NULL )
> > > continue;
> > > switch( poFieldDefn->GetType() )
> > > case OFTInteger:
> > > poFeature->SetField( iField,
> sqlite3_column_int( hStmt, iRawField ) );
> > > break;
> > > case OFTReal:
> sqlite3_column_double( hStmt, iRawField ) );
> > > break;
> > > case OFTBinary:
> > > const int nBytes = sqlite3_column_bytes( hStmt, iRawField
> > > poFeature->SetField( iField, nBytes,
> > > (GByte*)sqlite3_column_blob( hStmt, iRawField ) );
> > > break;
> > > case OFTString:
> > > poFeature->SetField( iField, (const char *)
> sqlite3_column_text( hStmt, iRawField ) );
> > > break;
> > > default:
> > > break;
> > > #ifdef notdef
> > > int iField = poStmt->GetColId( pszGeomColumn );
> > > const char *pszGeomText = poStmt->GetColData( iField );
> > > OGRGeometry *poGeom = NULL;
> > > if( pszGeomText != NULL )
> > > OGRGeometryFactory::createFromWkt( (char **)
> &pszGeomText,
> > > NULL, &poGeom );
> > > if( poGeom != NULL )
> > > poFeature->SetGeometryDirectly( poGeom );
> > > #endif
> > > if (hStmt)
> > > sqlite3_finalize(hStmt);
> > > return poFeature;
> > > 4. Rebuild gdal. Note that this change only optimizes the
> > GetFeature(long
> > > nFeatureId) method of a layer opened by a call to ExecuteSQL(). At
> least
> > > random access calls are fast then. I can also make the change in the
> > > OGRSQLiteLayer and ogrsqlitetablelayer classes. The function will
> always
> > > work for random access calls because WHERE, ORDER BY and all other sql
> > > clauses are irrelevant when accessing a row by ID. Note that
> > > GetNextFeature() will still be slow although we could speed up that
> > function
> > > as well.
> > > ALSO here is the changes for MYSQL and POSTGRESQL for optimized random
> > > access.
> > > MYSQL:
> > > /* GetFeature() */
> > > OGRFeature *OGRMySQLResultLayer::GetFeature( long
> nFeatureId )
> > > iNextShapeId = bHasFid == TRUE ? nFeatureId - 1 : nFeatureId;
> > > /* Do we need to establish an initial query?
> > > if( hResultSet == NULL )
> > > CPLAssert( pszQueryStatement != NULL );
> > > poDS->RequestLongResult( this );
> > > if( mysql_query( poDS->GetConn(), pszQueryStatement ) )
> > > poDS->ReportError( pszQueryStatement );
> > > return NULL;
> > > hResultSet = mysql_store_result( poDS->GetConn() );
> > > poDS->ReportError( "mysql_use_result() failed on query." );
> > > return FALSE;
> > > /* Fetch absolute record.
> > > char **papszRow = NULL;
> > > unsigned long *panLengths = NULL;
> > > OGRFeature *poFeature = NULL;
> > > if ( mysql_num_rows( hResultSet ) );
> > > mysql_data_seek( hResultSet, iNextShapeId );
> > > papszRow = mysql_fetch_row( hResultSet );
> > > if( !papszRow ) return NULL;
> > > panLengths = mysql_fetch_lengths( hResultSet );
> > > if ( !panLengths ) return NULL;
> > > /* Process record.
> > > poFeature = RecordToFeature( papszRow, panLengths );
> > > return poFeature;
> > > POSTGRESQL:
> > > /* GetFeature()
> > > OGRFeature *OGRPGResultLayer::GetFeature( long nFeatureId )
> > > if (bHasFid == TRUE && nFeatureId < 1) return NULL;
> > > PGconn *hPGConn = poDS->GetPGConn();
> > > if (hCursorResult != NULL)
> > > PQclear( hCursorResult );
> > > poDS->FlushSoftTransaction();
> > > poDS->SoftStartTransaction();
> > > osCommand.Printf( "DECLARE %s CURSOR for %s", pszCursorName,
> > > hCursorResult = PQexec(hPGConn, osCommand );
> > > osCommand.Printf( "FETCH ABSOLUTE %d in %s", nFeatureId,
> pszCursorName
> > > OGRFeature *poFeature = RecordToFeature( 0 );
> > > return poFeature;
> > > Best regards,
> > > Martin
> > > From: P Kishor [mailto:punk.kish at gmail.com] Sent: Sunday, April 13, 2008
> 6:56 PM
> > > To: Martin Chapman
> > > Cc: PostGIS Users Discussion; Richard Greenwood; Stephen Woodbridge
> > > On 4/13/08, Martin Chapman <mchapman at texelinc.com> wrote:
> > > > I'm working on it right now and will send you the code when I finish.
> > > > Basically SQLite is fast and the OGR code that uses sqlite is slow
> > > because
> > > > of the way they wrote it. My changes make OGR use random access
> versus
> > > what
> > > > they do today and scroll from 0 to n for each record requested. That
> > > means
> > > > that row one will return quick but for each sub-sequent request the
> code
> > > > loops until it finds the record requested. Very inefficient. It has
> > > speed
> > > > it up by about 50x on the very small shape file I am using to test.
> > > Fantastic! Please consider sharing the code with Frank. He is the
> > > ultimate custodian for OGR, and we want OGR itself to become better to
> > > the extent that it can.
> > > In the meantime, Frank, thanks yet again for making this possible (and
> > > for help with the OGR syntax).
> > > la la la (me happy again).
> > > > Best regards,
> > > > Martin
> > > > Sent: Sunday, April 13, 2008 6:41 PM
> > > > To: PostGIS Users Discussion
> > > > Cc: Richard Greenwood; Stephen Woodbridge; Martin Chapman
> > > > Subject: Speeding up SQLiteGIS
> > > > (started a new thread)
> > > > > I can connect to SQLite using OGR in my application as seen in the
> > > > > attachment. It's kind of slow compared to shape but I can
> optimize
> > > the
> > > > OGR
> > > > > code for SQLite like I did for PostgreSQL and MySQL in my local
> copy
> > > of
> > > > the
> > > > > gdal code. Then it's as fast as shape. I really like SQLite as
> well.
> > > > What
> > > > > is the address of your WMS server?
> > > > Martin,
> > > > I am right now working on my laptop, but will soon put it on a
> > > > publicly accessible server. I am fooling around with a few tricks,
> and
> > > > now I am getting the entire table being selected *and* rendered in
> > > > about 92 ms. I think that is *very* good (this is a table of all the
> > > > zip code boundaries in the State of Wisconsin, US -- 1121 rows and
> all
> > > > the river segments -- > 183K rows).
> > > > Now, could you kindly share the "optimization" of OGR code *for*
> > > > SQLite? Have you considered submitted it back to Frank for possible
> > > > inclusion in the main branch?
> > > > Also, we could request OSGeo to set up some space for us to share
> > > > SQLite code, tricks, etc. In the meantime, I have bagged
> sqlitegis.org
> > > > and sqlitegis.com, and would be happy to host a wiki/list or whatever
> > > > crap the dreamhost allows me to host with a single-click install.
> > > > Seriously, this the first time in years that I have been excited by
> > > > all this mapping business. SQLite is just such an incredibly powerful
> > > > tool, not for its power and performance (which is plenty fast for me)
> > > > but for its incredible simplicity. The fasted program for me is the
> > > > one that allows me to install, setup and program the fastest.
> > > > > Best regards,
> > > > > Martin
> > > > > From:
> postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of P
> > > > Kishor
> > > > > Sent: Sunday, April 13, 2008 1:51 PM
> > > > > To: PostGIS Users Discussion; Richard Greenwood
> > > > > Subject: Re: [postgis-users] SQLite and postGIS
> > > > > On 4/13/08, Richard Greenwood <richard.greenwood at gmail.com> wrote:
> > > > > > I should note that ogr2ogr creates a SQLite spatial table even
> more
> > > > > > easily that SpatiaLite:
> > > > > > ogr2ogr -f "SQLite" dest.db source.shp source
> > > > > Thanks Rich. You made my day. I am drawing a layer with about 185K
> > > > > rows, and, yes, there is a time lag, but this is out-of-the-box
> > > > > performance.
> > > > > One question -- the above ogr2ogr command, for me, does not seem
> to
> > > > > cooperate when adding multiple shapefiles to the same db. If I do
> > like
> > > > > so
> > > > > ogr2ogr -f "SQLite" dest.db source1.shp source2.shp source3.shp
> > > > > I get a dest.db with 0 Kb. I got around that by creating dest1.db,
> > > > > dest2.db and so on, and then creating dest.db, attaching the other
> > > > > dbs, and moving the tables into dest.db via
> > > > > CREATE TABLE ... AS SELECT * FROM....
> > > > > This seems a bit goofy, so I am sure I am doing something wrong
> with
> > > > > the ogr command. Suggestions?
> > > > > Another note -- I wonder if this merits starting a separate
> SQLitegis
> > > > > mailing list? I am happy here as long as the pg users don't mind.
> > > > > > Rich
> > > > > > On Sun, Apr 13, 2008 at 9:26 AM, Richard Greenwood
> > > > > > > On Fri, Apr 11, 2008 at 9:29 PM, Frank Warmerdam
> > > > <warmerdam at pobox.com>
> > > > > wrote:
> > > > > > > > Puneet, Rich,
> > > > > > > > SQLite is already supported as a spatial database by OGR.
> > > The
> > > > > caveat
> > > > > > > > is that in GDAL 1.5 it is just using a text column with
> WKT
> > > > > geometries so
> > > > > > > > the spatial performance is not great.
> > > > > > > > To use this with MapServer you would use CONNECTIONTYPE
> OGR
> > > and
> > > > the
> > > > > > > > CONNECTION string would be the path for the sqlite
> database.
> > > > The
> > > > > > > > DATA statement should hold the table name be accessed.
> > > > > > > Totally cool!
> > > > > > > I used SpatiaLite
> (http://www.gaia-gis.it/spatialite/)
> > > > LoadShapefile()
> > > > > > > function to import a shapefile into a SQLite db. The
> geometries
> > > are
> > > > > > > stored as BLOBs in a field named "geom" Then:
> > > > > > > sqlite> alter table ownership add column WKT_GEOMETRY;
> > > > > > > sqlite> update ownership set WKT_GEOMETRY=astext(geom);
> > > > > > > Getting MapServer to use the SQLite table was very easy.
> Recent
> > > > > > > versions of MS4W have SQLite support in GDAL. So simply
> adding
> > > > > > > CONNECTIONTYPE OGR
> > > > > > > CONNECTION "path/to/SQLite.db"
> > > > > > > gets MapServer drawing geometries from SQLite.
> > > > > > > I'm playing with a table containing about 15,000 polygons
> and
> > > > > > > performance is fine.
> > > > > > > Thanks Frank, for pointing me in the right direction.
> > > > > > > Rich
> > > > Puneet Kishor http://punkish.eidesis.org/
> > > > Nelson Institute for Environmental Studies
> http://www.nelson.wisc.edu/
> > > > Open Source Geospatial Foundation (OSGeo) http://www.osgeo.org/
Nelson Institute for Environmental Studies http://www.nelson.wisc.edu/
