[postgis-users] Cut off 1-acre of a parcel
Obe, Regina
robe.dnd at cityofboston.gov
Tue Apr 15 04:54:54 PDT 2008
John,
Very interesting problem. First I am going to assume you have chosen a
Feet based spatial ref system and no parcel you have is greater than
250 x 250 acres across.
I'm going to break up your parcels into ~ 1/4 acres.
I'm sure I'll screw up in my logic here, but hopefully it will be enough
to get you going.
My idea is similar to yours except I am starting in south east corner
since that is the standard PostGIS origin
One way that comes to mind is to
1) First create a new table with your parcels clipped up into say 1/4th
acre units (I just need it to be lower than one acre to deal with
shards) with a parcel identifier denoting the parcel this slice is
formed from, the geometry, 2 fields -start_year (which you set to year
you started), ~year_used - which you update with your forecasting year.
To do part 1 I would use a combo of ST_Translate, ST_Intersection,
generate_series something of the form.
SELECT p.parcel_id, hor.n As shard_hpos, ver.n As shard_vpos, 2008::int
As year_started, null::int As year_used,
ST_Intersection(p.the_geom, ST_translate(p.boxref, hor.n*width,
ver.n*height)) As the_shard
INTO my_parcel_shards
FROM (SELECT parcel_id,
ST_SetSRID(ST_MakeBox2D(ST_MakePoint(ST_Xmin(the_geom),
ST_Ymin(the_geom)),
ST_MakePoint(ST_Xmin(the_geom) + 52, ST_Ymin(the_geom) + 52)),
your_srid_goes_here) As boxref
As boxref FROM parcels) p CROSS JOIN generate_series(0,
1000) As hor(n)
CROSS JOIN generate_series(0,1000) As ver(n)
WHERE ST_Intersects(p.the_geom, ST_translate(p.boxref, hor.n*width,
ver.n*height))
2) Next continuously update the year_used field for each forecast year.
(This part I am sure I probably screwed up on, but hopefully
you get the idea). The year_used marker will denote the year that shard
was used.
UPDATE my_parcel_shards
SET year_used = whatever_forecast_year_we_are_up_to
FROM (SELECT f3.parcel_id, MIN(shard_hpos) as hpos,
MIN(shard_vpos) As vpos
FROM (SELECT parcel_id, shard_hpos, shard_vpos,
SUM(ST_Area(f2.the_shard)) As amt_used
FROM my_parcel_shards f1 INNER
JOIN my_parcel_shards f2
ON (f1.parcel_id =
f2.parcel_id)
WHERE f1.shard_hpos >=
f2.shard_hpos AND
f1.shard_vpos >= f2.shard_hpos
AND f1.year_used IS NULL
AND f2.year_used IS NULL
) f3
f3.amt_used >= 43560 AND f3.amt_used <=
46264
GROUP BY f3.parcel_id) As forecast
WHERE my_parcel_shards.parcel_id = forecast.parcel_id
AND my_parcel_shards.shard_hpos <= forecast.hpos
AND my_parcel_shards.shard_vpos <= forecast.vpos
AND year_used IS NULL;
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of John
Abraham
Sent: Monday, April 14, 2008 8:11 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Cut off 1-acre of a parcel
Hi there. I'm a fairly new user of PostGIS, but I think I finally have
it figured out and I'm finding it *very* useful and productive.
Now I'm ready to tackle one of my larger problems. I'm working with a
cadastral layer and forecasting future development patterns. I have a
need to simulate subdivision, where a large vacant parcel (say, 640
acres) will realistically be developed in the future in smaller chunks
(say, 1 acre). Right now I ignore the spatial part of it, and end up
having multiple future "pseudo-parcels" associated with one current-year
parcel. So, for instance, if the simulation has two 1-acre development
events in year 2010 and one 1-acre development event in year 2012, all
occurring on the same original 640 acre parcel, then in year 2013 I have
4 records associated with the original 640 acre parcel: a 637 acre
record that is still vacant, and three 1 acre records representing the
development that has occurred. All four of these records are still
associated with the same polygon.
For the general predictive power of the model and for the mathematics
behind it, this is ok, at least for now. But for visualization, this
isn't ok. For visualization, I'd like a separate (non-overlapping)
polygon for each of these records. I need an algorithm that takes off
an arbitrary 1acre chunk of the large parcel each time a development
event is simulated for it.
The algorithm I'd like to use (unless someone suggests a better one) is.
1) find the east edge of the bounding box for the polygon.
2) draw a north-south line that is sqrt(43560) ft to the west of the
east edge of the bounding box, and consider the areas on either side.
3) if the area on the east of the line is less than 1-acre, move the
line west until the area on the east of the line is exactly one acre,
done (stop).
4) else, draw an east-west line through the polygon far enough south so
that the area north-east of the intersection of the two lines is exactly
1 acre.
I'm pretty sure this algorithm will grab 1-acre chunks of the original
parcel starting in the north-east, and working down the east side, and
when the east side is completely separated, it will start again at the
new north-east corner and work down that side. So the parcel will be
slowly "subdivided" as development occurs from the east to the west in
strips. Since there are 43560 sqft in an acre, most of the chunks will
be square. (If the original polygon is non-convex, then the subdivided
pieces may end up being multi-polygons, but that's ok, I can deal with
multi-polygons, so long as the subdivision algorithm can handle it.
There will also be some rather long-and-thin slivers, I think; it would
actually be better to spiral around the parcel, working towards the
inside in a circle, instead of always coming from the east side. But...
I think this algorithm will work, and once it's working I can "tweak" it
later.)
Can anyone give me some pointers as to how to code this up in PostGIS?
I have a few clues as to how to draw a line sqrt(43560) ft from the east
side, but I don't have any clues about how to draw a line "far enough
south so that the resulting area is exactly 1 acre". I could try some
sort of trial-and-error bisection algorithm, I suppose, but I expect
there might be a much easier way.
Any and all comments appreciated, thanks
John Abraham
jabraham at ucalgary.ca
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
