[postgis-users] FOSS4G Architectures/options for Distributed DBs
Brent Wood
pcreso at pcreso.com
Wed Apr 16 11:42:09 PDT 2008
Hi Tim,
Just one point, you suggest Mapguide as part of the solution, I'm not sure if
you mean Mapguide OpenSource (as a FOSS package) or Mapguide Enterprise/Studio
(commercial packages sold by Autodesk IIRC).
Given the FOSS based discussion, I'm assuming the OS version, but figured this
is worth clarifying.
Cheers,
Brent Wood
--- Tim Bowden <tim.bowden at westnet.com.au> wrote:
> On Wed, 2008-04-16 at 11:30 +0200, Willy-Bas Loos wrote:
> > Hi Shaun,
> > I think i saw a colleage of yours at the FOSS4G2007, Tim Bowden.
> > http://www.foss4g2007.org/presentations/view.php?abstract_id=261
> > (i'm missing the presentation file at the website, maybe put it up
> > there?)
> > Back then it sounded like you had things solved. What's the factor
> > that has been added to the problem?
> > The client interface?
> Firstly, you're assuming my presentation was for Shaun's project (though
> yes, I have done work for him in the past). That's not something I've
> said at any point. With that out of the way...
> >From my pov, there is a solution (small scale trialed but not yet prod
> tested!) to the distributed data part. It would seem Shaun's /current/
> requirements involve a little more integration into the existing
> enterprise GIS system (SDE), along with integrating a proprietary field
> solution. As far as I see it, those requirements aren't show stoppers
> by any means. From the requirements given, I can't see any solution
> that doesn't involve reasonable dev costs.
> FWIW, I believe a distributed postgis db (between site and central),
> using Mapguide as an interface at each site office is the most cost
> effective way of getting an "enterprise" type solution (with all the
> business baggage that entails). If anyone has any alternate suggestions
> that don't involve significant dev costs, I'd also love to hear them.
> Personally, I believe any solution in such a distributed environment is
> going to cost enough dollars to make it a budget item in its own right.
> There's a lot of dev, testing and tweaking to get everything going
> smoothly with the constraints you've got there Shaun. Unfortunately
> that means dollars.
> HTH,
> Tim Bowden
> > Cheers,
> > WBL
> > On Mon, Apr 14, 2008 at 11:37 PM, Shaun Kolomeitz
> > <Shaun.Kolomeitz at epa.qld.gov.au> wrote:
> > This is not strictly a PostGIS issue, but PostGIS could be one
> > part of
> > the solution (I think) ?
> > I'm curious as to what the broader community thinks would be a
> > workable
> > solution for our spatial business problem from a FOSS4G
> > perspective.
> > We have a broad area network of around 600 clients spread
> > across an area
> > of 1500 x 1900 km in the State of Queensland, Australia.
> > Primarily our
> > clients are Rangers and Resource Managers, managing their
> > "patch of
> > dirt" (Flora, Fauna, Fire, Pests, Assets, Visitor, Camping,
> > Heritage,
> > etc).
> > 150 or so are currently located on remote Satellite
> > connections (with
> > latency issues) reducing to 50 by the end of the year. The
> > rest are
> > split between NextG, ADSL and WAN type connections. Satellite
> > connections in particular may not be available in bad weather
> > conditions.
> > In the past we've had ArcView 3.x as a custom client app
> > running locally
> > and now we're looking to the future.
> > The system is used in the office as a planning tool for field
> > activities
> > (such as a new fence, fire break, pest treatment) before
> > heading out
> > into the paddock.
> > Users collect (capture) a variety of information while in the
> > field
> > relating to the above activities mentioned (Fire, Pests,
> > Assets etc) and
> > send zipped shapefiles via email through our network of
> > contacts twice a
> > year to head office. At the moment only Fire and Pest info is
> > sent,
> > although we'd like users around the state to be more
> > collaborative (from
> > a data sense).
> > The only real givens are that we'll have a corporate GIS
> > repository
> > storing all corporate data in an Oracle SDE db in head office,
> > and that
> > the users will be taking data with them into the field (no
> > connection to
> > ANY network).
> > I'm pretty sure we'll be using ArcPad as our field-based app
> > (on
> > handhelds and tablets/laptops).
> > Our main business problems are -
> > 1) Providing a simple to use system which acts as a "portal"
> > to a range
> > of spatial and non-spatial data and systems relevant to the
> > users patch
> > 2) Simplifying (or automating) the update of data to/from the
> > park base
> > to the head office
> > 3) Managing data as it is "checked-out" for field use and then
> > "checked-in" after it comes back, while not providing too much
> > of an
> > overhead for the users
> > 4) Providing a basic GIS ability (similar to ArcView 3.x)
> > 5) Providing a means of integrating information in other
> > datasets (fire,
> > pests) and across other dbs (WildLife db) or applications
> > (Assets, etc)
> > 6) Providing multi-user access to individual datasets
> > 7) Providing redlining, markup and a collaboration type
> > ability
> > 8) Providing a standard look-and-feel to any client
> > I'm happy to discuss further if need be.
> > As always any assistance would be greatly appreciated.
> > We are trying to work on a response to our executive within 13
> > days.
> > Kind regards,
> > Shaun Kolomeitz,
> > Senior Technical Officer
> > Business and Asset Services
> > Queensland Parks and Wildlife Division
> > Environmental Protection Agency
> > Think B4U Print
> > 1 ream of paper = 6% of a tree and 5.4kg CO2 in the atmosphere
> > 3 sheets of A4 paper = 1 litre of water
> > _________________________
> > Disclaimer
> > WARNING: This e-mail (including any attachments) has
> > originated from a Queensland Government department and may
> > contain information that is confidential, private, or covered
> > by legal professional privilege, and may be protected by
> > copyright.
> > You may use this e-mail only if you are the person(s) it was
> > intended to be sent to and if you use it in an authorised
> > way. No one is allowed to use, review, alter, transmit,
> > disclose, distribute, print or copy this e-mail without
> > appropriate authority. If you have received this e-mail in
> > error, please inform the sender immediately by phone or e-mail
> > and delete this e-mail, including any copies, from your
> > computer system network and destroy any hardcopies.
> > Unless otherwise stated, this e-mail represents the views of
> > the sender and not the views of the Environmental Protection
> > Agency.
> > Although this e-mail has been checked for the presence of
> > computer viruses, the Environmental Protection Agency provides
> > no warranty that all viruses have been detected and cleaned.
> > Any use of this e-mail could harm your computer system. It is
> > your responsibility to ensure that this e-mail does not
> > contain and is not affected by computer viruses, defects or
> > interference by third parties or replication problems
> > (including incompatibility with your computer system).
> > E-mails sent to and from the Environmental Protection Agency
> > will be electronically stored, managed and may be audited, in
> > accordance with the law and Queensland Government Information
> > Standards (IS31, IS38, IS40, IS41 and IS42) to the extent they
> > are consistent with the law.
> > ___________________________
> > !DEPTSTAMP1!
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
