[postgis-users] problem loading lwpostgis.sql - libgeos
Paul Ramsey
pramsey at cleverelephant.ca
Fri Apr 18 07:05:17 PDT 2008
Can you re-build GEOS and run "make test"? The problem seems to be a
symbol that GEOS can't find rather than one lwpostgis can't find.
P
On Fri, Apr 18, 2008 at 3:09 AM, Ronald Woita <Ronald.Woita at rostock.de> wrote:
> Hi list,
> I have a problem loading the lwpostgis.sql into a database.
> (plpgsql is already loaded)
> this is the message from Postgres-Serverlog :
> NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> ERROR: could not load library "/usr/local/pgsql/lib/liblwgeom.so":
> /usr/local/lib/libgeos-3.0.0.so: undefined symbol:
> _ZTVN10__cxxabiv120__si_class_type_infoE
> STATEMENT: CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
> RETURNS histogram2d
> AS '/usr/local/pgsql/lib/liblwgeom', 'lwhistogram2d_in'
> LANGUAGE 'C' IMMUTABLE STRICT;
> ERROR: current transaction is aborted, commands ignored until end of
> transaction block
> (for complete log see attachement)
> ldd liblwgeom.so provides this :
> linux-gate.so.1 => (0xffffe000)
> libgeos_c.so.1 => /usr/local/lib/libgeos_c.so.1 (0xb7e7a000)
> libproj.so.0 => /usr/local/lib/libproj.so.0 (0xb7e48000)
> libc.so.6 => /lib/libc.so.6 (0xb7d27000)
> libgeos-3.0.0.so => /usr/local/lib/libgeos-3.0.0.so
> (0xb7aac000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7aa0000)
> libm.so.6 => /lib/libm.so.6 (0xb7a7b000)
> /lib/ld-linux.so.2 (0x80000000)
> I checked the libraries and did'nt found any errors.
> the necessary path variables /usr/local/pgsql/lib and /usr/local/lib
> are correctly listed in /etc/ld.so.conf
> any hints welcome !
> The System Enviroment is
> PostgeSQL 8.3.1
> PostGIS 1.3.3
> GEOS-3.0.0
> on SLES 10SP1
> best regards
> Ronald
> postgis-users mailing list
