[postgis-users] Does anyone have multipolygons withlarge numbersof polygons
Paragon Corporation
lr at pcorp.us
Sat Apr 19 04:20:14 PDT 2008
It could be the reentry and prepare of the geom that is the culprit. I
haven't looked at the code, but from thinking about it, would think there
would be some repetitive setup involved in each case (even if passing were
efficient) and then pulling out a single point from a reprepared array of
points.
Given that PostgreSQL has this side effect behavior of allowing set
returning functions in the SELECT part. Couldn't we then create a SPLIT BY
geom function similar to DUMP, but returns a set of geoms instead of a dump
object.
Then Kevin's query would be reduced to
SELECT t.gid, Geom_SplitBy(the_geom, 'POINT') as the_geom
FROM
kneufeld.tmp t
You could even have an overloaded allows a range of geoms to pull that does
SELECT t.gid, Geom_SplitBy(the_geom, 'POINT', 1,5) as the_geom
FROM
kneufeld.tmp t
Types would map to our GeomN type functions like PointN, GeometryN,
InteriorRingN. This would avoid any pass by value inefficiencies since
the_geom would be passed only once and would allow for internal efficiencies
of pulling multiple geometries.
As a side note: A colony of mice is much more fun to play with than a puppy
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Martin
Davis
Sent: Friday, April 18, 2008 5:25 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Does anyone have multipolygons withlarge
numbersof polygons
Yes, I absolutely agree - SPLIT BY should take "Inverse Aggregate"
functions, which can be provided for *any* complex object. The example they
give in the Manifold doc is classic - split a string into "chunks"
at given characters (or regexes...). It's funny that they give that example
- but it isn't actually supported by Manifold!
So it looks like it's the pass-by-value semantics which are slowing things
down, not the generate_series idiom. Hopefully a SPLIT BY facility would be
able to avoid this problem - or would it?
While we're waiting for that, Regina, I suggest maybe getting a puppy? 8^)
Obe, Regina wrote:
> I remember looking at Manifold's SPLIT BY function and thinking -
> "that's what I'm missing in my life - a inverse GROUP BY."
> I was disappointed to find out that there SPLIT BY only supports 3
> split functions which makes it much more limiting than the
> generate_series approach. It makes nice syntactic sugar at the very
> least and perhaps if PostgreSQL could implement SPLIT TYPE functions
> which would be the inverse of the AGGREGATE functions, then this
> would be much more interesting.
> Looking at Kevin's results I am beginning to think the bottleneck may
> be in the GeomN type functions and maybe he is right that its doing a
> copy call for each or something silly like that or a memory leak (I
> wasn't looking is it linear or quadratic as the number of geometries
> increases?).
> I'm relieved the sub select thing came up with the same results as if
> it was better it would have shattered some of my beliefs on how things
> work.
> Kevin,
> What happens if you leave out the PointN call altogether just to see
> what kind of penalty is being incurred there.
> e.g.
> SELECT t.gid, generate_series(1, ST_NumPoints(the_geom)) FROM
> kneufeld.tmp t
> Thanks,
> Regina
> Martin Davis
> Sent: Friday, April 18, 2008 2:22 PM
> Subject: Re: [postgis-users] Does anyone have multipolygons with large
> numbersof polygons
> This is an interesting problem. I think the general pattern can be
> stated as something like: "Split a complex column value across
> multiple rows, along with other columns from the original record". (A
> nice way of thinking of this is that it's the inverse of GROUP BY).
> This is surprisingly awkward to do in standard SQL. It's easier in
> PostgreSQL since it has the generate_series() enhancement, but as you
> are seeing it's still not a great general solution to the problem.
> The annoying thing is is that the underlying processing required to
> compute the desired result is actually pretty trivial. This is one of
> those situations where the fairly limited declaritive semantics of SQL
> get in your way.
> Manifold SQL has an extension which adds a SPLIT BY clause to handle
> exactly this problem. I suspect they have a pretty efficient
> implementation, since it is implemented natively in the engine.
> http://www.manifold.net/doc/queries_and_geoms.htm
> Maybe it's time to lobby to get this added to PostgreSQL as well?
> Obe, Regina wrote:
>> I know there has been some discussion in the past about how
>> generate_series doesn't scale well when you are dealing with large
>> numbers of geometries. My suspicion was that it was because
>> generate_series has to materialize the result before outputting it
>> and that the result key is not indexed.
>> Unfortunately I don't have geometries large enough to test the theory
>> out, but does seem to be faster for me even for structures where I
> have
>> more than 10 or geometries per multipolygon. Can some people try
>> this out. The below will take each multi geom and break it out into
>> single geom structures and will handle in theory a MULTI structure
>> with up to 500,000 geoms and can easily handle more by increasing the
>> number of records in the materialized generate series table.
>> Can you compare this:
>> SELECT g.n
>> INTO pgis_gs
>> FROM generate_series(1,500000) g(n);
>> ALTER TABLE pgis_gs
>> ADD CONSTRAINT pgis_gs_pkey PRIMARY KEY(n);
>> SELECT t.gid, ST_GeometryN(the_geom, g.n) As poly FROM somtable t
>> CROSS JOIN pgis_gs g WHERE g.n <= ST_NumGeometries(the_geom);
>> With these:
>> --this will handle at most 5000 (for small sets of geometries -
>> incurs
> a
>> huge penalty)
>> CROSS JOIN generate_series(1,5000) g(n) WHERE g.n <=
>> -this can handle more but I suspect gets really bad for large numbers
>> SELECT t.gid, ST_GeometryN(the_geom, ST_NumGeometries(the_geom)) As
> poly
>> FROM somtable t;
>> Thanks,
>> Regina
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended solely for the
>> addressee. If you received this in error, please contact the sender
>> and delete the material from any computer.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
