[postgis-users] ERROR: type "postgis.geometry" is only a shell
Stefan Schwarzer
stefan.schwarzer at grid.unep.ch
Sun Apr 20 23:59:22 PDT 2008
I installed postgres & postgis (with Kyngchaos packages). Dumped the
database from the server:
pg_dump -i -h <ip_address> -p 5432 -U postgres -F c -v -f dump.c.sql
<database>
and then re-stored:
pg_restore -i -U postgres -d <database> -v dump.c.sql
But when it comes to the PostGIS data tables (like country
boundaries), I get this error message:
pg_restore: creating TABLE admin01
pg_restore: [archiver (db)] Error from TOC entry 6472; 1259 3178500
TABLE admin01 ss_admin
pg_restore: [archiver (db)] could not execute query: ERROR: type
LINE 8: the_geom postgis.geometry,
Command was: CREATE TABLE admin01 (
gid integer NOT NULL,
cntry_name character varying(42),
cntry_code character varying(13),...
pg_restore: [archiver (db)] could not execute query: ERROR: relation
"gis.admin01" does not exist
Command was: ALTER TABLE gis.admin01 OWNER TO ss_admin;
What is this? What can I do?
Thanks for any hints,
Stef
