[postgis-users] Difference between @ and ST_WITHIN/ST_CONTAINS
Josh Livni josh at umbrellaconsulting.com
Tue Apr 22 09:36:18 PDT 2008
The @, and other operators such as &&, work on the bounding boxes of
geometries.  The st_xxx functions additionally do calculations using the
actual geometries themselves...
  -Josh
Frank Durstewitz wrote:
> Hi,
> can someone please explain, what the difference between
> WHERE ST_CONTAINS(b.geom, e.geom)
> and
> WHERE e.geom @ b.geom
> is? (b.geom are (multi-)polygons and e.geom are points)
> I expect to get the same results, but with @ i get a few more records...?
> TIA, Frank
> postgis-users mailing list
