[postgis-users] Difference between @ and ST_WITHIN/ST_CONTAINS
Dylan Beaudette dylan.beaudette at gmail.com
Tue Apr 22 10:27:24 PDT 2008
On Tuesday 22 April 2008, Paul Ramsey wrote:
> The operators (@, &&, etc) all work on bounding boxes. The functions
> all work on full geometries. It is possible for geometries to satisfy
> bounding box containment while not satisfying full geometric
> containment, hence your discrepancy.
> P.
Thanks for the clarification.
Does it make sense any more to use one of the &&, @, etc. operators to
pre-filter geometries, or do the ST_ functions take care of that in call
cases? i.e. can you think of any cases where it would still be a good idea to
use something like
select st_intersection(a,b)
from a, b
on a && b ;
Thanks,
Dylan
> On Tue, Apr 22, 2008 at 8:36 AM, Frank Durstewitz
> <frank.durstewitz at emporis.com> wrote:
> > Hi,
> >  can someone please explain, what the difference between
> >  WHERE ST_CONTAINS(b.geom, e.geom)
> >  and
> >  WHERE e.geom @ b.geom
> >  is? (b.geom are (multi-)polygons and e.geom are points)
> >  I expect to get the same results, but with @ i get a few more
> > records...?
> >  TIA, Frank
> >  postgis-users mailing list
> >  postgis-users at postgis.refractions.net
> >  http://postgis.refractions.net/mailman/listinfo/postgis-users
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
