[postgis-users] Absolute Beginner
Bob Pawley
rjpawley at shaw.ca
Tue Apr 22 10:30:09 PDT 2008
Thanks Regina
My version of PostgreSQL has no functions that start with ST_ such as
ST_GeomFromText.
I removed the ST_ from the code you suggested making it GeomFromText and it
worked well.
What does the ST_ signify??
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, April 22, 2008 5:21 AM
Subject: RE: [postgis-users] Absolute Beginner
Bob,
Unfortunately I'm not too familiar with Delphi (aside from its some
Pascal derivative) and I guess no one is in this group since no one
responded to your question.
I guess it depends what Delphi is expecting for the Canvas - e.g. can it
use SVG maybe or most unlikely (WKT or WKB representations). At
anyrate I suspect you are more likely to find Delphi plugins for
rendering SVG than any other format output by PostGIS.
If you can find SVG plugins, there is an asSVG function in PostGIS that
may prove useful to you.
As far as storing the path, you could put it in your database as a
LINESTRING of the form
INSERT INTO temppath(fieldname)
VALUES(ST_GeomFromText('LINESTRING(1 2,3 12)'))
You can ignore use of SRID since you don't care about Geography.
Then query it as SVG format with
SELECT AsSVG(fieldname)
FROM temppath
or expand it out to x and y with something like
SELECT somekeyfield, ST_x(the_geom) as x, ST_y(the_geom) as y
FROM
(SELECT somekeyfield, ST_PointN(fieldname, generate_series(1,
ST_numpoints(fieldname)) As the_geom
FROM temppath) as foo
That will give you the x and y coordinates of each point of the line
string (with all belonging to the same linestring having
the same somekeyfield
and then you can just plot the x and y on canvas.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
Pawley
Sent: Monday, April 21, 2008 1:25 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Absolute Beginner
I know that most, if not all, on this list are interested in the
geography
side of GIS.
However, I have a question on the geometry side.
I have a Delphi Canvas that I need to connect to a PostgreSQL database.
What is the minimum table structure that is needed to hold the vector
coordinates such as this path ((1,2), (3, 12)) so that it will draw the
line
in Delphi?
Perhaps the Delphi knowledgeable people can let me know if the following
query is any where near correct to accomplish this action.
Thanks in advance.
Bob
PSQLQuery1.Close;
PSQLQuery1.SQL.Clear;
PSQLQuery1.SQL.Add ('Select * fieldname ');
PSQLQuery1.SQL.Add ('FROM temppath');
PSQLQuery1.Prepare;
PSQLQuery1.Open;
PSQLQuery1.First ;
i2:= PSQLQuery1.FieldByName('fieldname').AsInteger ;
testfrm:= IntToStr(i2);
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
