[postgis-users] Absolute Beginner
Paragon Corporation
lr at pcorp.us
Tue Apr 22 11:53:50 PDT 2008
Bob,
David is right. You are probably running an early 1.2 or 1.1 install.
SELECT postgis_full_version()
Is slightly better to run - it will give you details of Geos too.
ST is the new naming convention. For things that use spatial indexes, it
automagically includes the spatial index operators
For example
geom1 && geom2 AND Intersects(geom1,geom2)
is equivalent to
ST_Intersects(geom1,geom2)
For the examples I provided below, those don't use spatial indexes so they
are equivalent to the ones without the ST_
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Dave
Potts
Sent: Tuesday, April 22, 2008 1:59 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Absolute Beginner
Bob Pawley wrote:
I suspect your not using the latest version of postgis. The command select
postgis_version(); will return which version use are using.
D.
> Thanks Regina
> My version of PostgreSQL has no functions that start with ST_ such as
> ST_GeomFromText.
> I removed the ST_ from the code you suggested making it GeomFromText
> and it worked well.
> What does the ST_ signify??
> Bob
> ----- Original Message ----- From: "Obe, Regina"
> <robe.dnd at cityofboston.gov>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Tuesday, April 22, 2008 5:21 AM
> Subject: RE: [postgis-users] Absolute Beginner
> Bob,
> Unfortunately I'm not too familiar with Delphi (aside from its some
> Pascal derivative) and I guess no one is in this group since no one
> responded to your question.
> I guess it depends what Delphi is expecting for the Canvas - e.g. can
> it use SVG maybe or most unlikely (WKT or WKB representations). At
> anyrate I suspect you are more likely to find Delphi plugins for
> rendering SVG than any other format output by PostGIS.
> If you can find SVG plugins, there is an asSVG function in PostGIS
> that may prove useful to you.
> As far as storing the path, you could put it in your database as a
> LINESTRING of the form
> INSERT INTO temppath(fieldname)
> VALUES(ST_GeomFromText('LINESTRING(1 2,3 12)'))
> You can ignore use of SRID since you don't care about Geography.
> Then query it as SVG format with
> SELECT AsSVG(fieldname)
> FROM temppath
> or expand it out to x and y with something like
> SELECT somekeyfield, ST_x(the_geom) as x, ST_y(the_geom) as y FROM
> (SELECT somekeyfield, ST_PointN(fieldname, generate_series(1,
> ST_numpoints(fieldname)) As the_geom
> FROM temppath) as foo
> That will give you the x and y coordinates of each point of the line
> string (with all belonging to the same linestring having the same
> somekeyfield
> and then you can just plot the x and y on canvas.
> Hope that helps,
> Regina
> Bob Pawley
> Sent: Monday, April 21, 2008 1:25 PM
> Subject: [postgis-users] Absolute Beginner
> I know that most, if not all, on this list are interested in the
> geography side of GIS.
> However, I have a question on the geometry side.
> I have a Delphi Canvas that I need to connect to a PostgreSQL database.
> What is the minimum table structure that is needed to hold the vector
> coordinates such as this path ((1,2), (3, 12)) so that it will draw
> the line in Delphi?
> Perhaps the Delphi knowledgeable people can let me know if the
> following query is any where near correct to accomplish this action.
> Thanks in advance.
> Bob
> PSQLQuery1.Close;
> PSQLQuery1.SQL.Clear;
> PSQLQuery1.SQL.Add ('Select * fieldname ');
> PSQLQuery1.SQL.Add ('FROM temppath');
> PSQLQuery1.Prepare;
> PSQLQuery1.Open;
> PSQLQuery1.First ;
> i2:= PSQLQuery1.FieldByName('fieldname').AsInteger ;
> testfrm:= IntToStr(i2);
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
