[postgis-users] ST_Contains() performance problem
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Apr 24 03:47:31 PDT 2008
Hi Stephan,
Stephan GrĂ¼ter wrote:
> Hi,
> after migration from PostgreSQL-8.2.4/PostGIS-1.2.1 to
> PostgreSQL-8.3.1/PostGIS-1.3.3
> I have massive performance problems doing point in polygon analyses with
> ST_Contains().
> Query:
> EXPLAIN ANALYZE
> SELECT geo.regcode, bez.name
> FROM reg.geometrien geo, reg.bezeichnungen bez
> WHERE geo.regtyp = 8
> AND geo.the_geom && GeomFromText('Point(682970.983613 246747.010965)',
> 21781)
> AND Contains(geo.the_geom, GeomFromText('Point(682970.983613
> 246747.010965)', 21781))
> AND geo.regtyp = bez.regtyp
> AND geo.regcode = bez.regcode;
It appears that all the time is disappearing into the nested loop with
filter. What does the EXPLAIN ANALYZE of the following look like:
EXPLAIN ANALYZE
SELECT geo.regcode FROM reg.geometrien geo
WHERE
geo.the_geom && GeomFromText('Point(682970.983613 246747.010965)', 21781)
This should return with a few ms. Bear in mind that the "geo.the_geom &&
GeomFromText('Point(682970.983613 246747.010965)', 21781)" section is
redundant with newer versions of PostGIS too.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
