AW: Re: AW: RE: [postgis-users] Geometrycollection to Multipolygon
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Thu Apr 24 06:20:17 PDT 2008
Horst,
I have what seems to be an ugly solution to your difficulty, but I think it works. I do a manipulation on the asText entities, stripping out the "POLYGON" label, and merging them together to form a MULTIPOLYGON. While this is ugly, it could form the basis of a simple function to achieve this, perhaps by iterating through an array collection. This example shows the creation of a MULTI with 3 component polygons:
select geomFromText('MULTIPOLYGON(' || a.poly || ',' || b.poly || ',' ||
c.poly ')',4326) as newgeom
from (select trim (leading 'POLYGON' from asText(geometryN(the_geom,1))) as
poly from proj_seggroups where gid = 5
) as a,
(select trim (leading 'POLYGON' from asText(geometryN(the_geom,2))) as
) as b,
(select trim (leading 'POLYGON' from asText(geometryN(the_geom,3))) as
) as c
The interesting part is, that I have checked this with a multi that has 5 polys in it, and when converted asText, they are identical, however, using the postgis Equals function declares them to be non-equal. Not sure exactly, but here is the query that I used to do this:
select Equals(foo.newgeom, bar.the_geom) from (
select geomFromText('MULTIPOLYGON(' || a.poly || ',' || b.poly || ',' || c.poly || ',' || d.poly || ',' || e.poly || ')',4326) as newgeom
from (select trim (leading 'POLYGON' from asText(geometryN(the_geom,1))) as poly from proj_seggroups where gid = 5)
as a,
(select trim (leading 'POLYGON' from asText(geometryN(the_geom,2))) as poly from proj_seggroups where gid = 5)
as b,
(select trim (leading 'POLYGON' from asText(geometryN(the_geom,3))) as poly from proj_seggroups where gid = 5)
as c,
(select trim (leading 'POLYGON' from asText(geometryN(the_geom,4))) as poly from proj_seggroups where gid = 5)
as d,
(select trim (leading 'POLYGON' from asText(geometryN(the_geom,5))) as poly from proj_seggroups where gid = 5)
as e
) as foo, (
select the_geom from proj_seggroups where gid = 5
) as bar;
Good luck!
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen Woodbridge
Sent: Wednesday, April 23, 2008 12:54 PM
To: Düster Horst
Cc: postgis-users
Subject: Re: AW: Re: AW: RE: [postgis-users] Geometrycollection to Multipolygon
I would expect to get a collection out of st_collect(), I think it is
strange (a bug?) that you get a multipolygon out of two polygons.
-Steve
Düster Horst wrote:
> Stephen
>>and see if you get a multipolygon ot a collection as the result.
> A collection is the result of course. The mix of two geometry types is
> the one reason, but your idea leeds also to a collection because your
> idea tries to collect two multigeometries. I believe it is not possible
> to merge multipolygons into one multipolygon like
> MULTIPOLYGON(MULTIPOLYGON1, MULTIPOLYGON2,...). This geometry has to be
> a collection.
> Horst
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> -----Ursprüngliche Nachricht-----
> Von: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Gesendet am: Mittwoch, 23. April 2008 17:59
> An: PostGIS Users Discussion
> Betreff: Re: AW: RE: [postgis-users] Geometrycollection to Multipolygon
> I think you are getting the collection because you are mixing types.
> Try this (I haven't tried it):
> st_collect(
> st_collect(st_multi(polygon1), st_multi(polygon2)),
> st_multi(polygon3))
> -Steve W
> Düster Horst wrote:
>> Regina
>> Thank you for your response. Mmmm.. your trick doesn't solve my problem.
>> Perhaps I should tell you why I do have a geometrycollection. My
>> startingpoint is a sequence of single polygons. My aim is to merge them
>> together to one multipolygon. I do this with st_collect. This works fine
>> with two polygons:
>> st_collect(polygon1,polygon2) => multipolygon(1,2).
>> When I Process the third polygon with: st_collect(multipolygon(1,2),
>> polygon3) => Geometrycollection(multipolygon(1,2),polygon3)
>> I do get the geomtrycollection and so on.
>> My main problem is to merge the three polygons into one multipolygon
>> with 3 geometries.
>> When I solve this problem I can offer a procedure to clean invalid
>> geometries.
>> Regards
>> Horst
>> Dr. Horst Düster
>> Kanton Solothurn
>> SO!GIS Koordination
>> Rötistrasse 4
>> CH-4501 Solothurn
>> http://www.agi.so.ch <http://www.agi.so.ch/>
>> *Von:* Obe, Regina [mailto:robe.dnd at cityofboston.gov]
>> *Gesendet am:* Mittwoch, 23. April 2008 14:24
>> *An:* PostGIS Users Discussion
>> *Betreff:* RE: [postgis-users] Geometrycollection to Multipolygon
>> This sometimes does the trick for me if they actually can be unioned
>> ST_Union(GEOMCOLL, ST_GeomFromText('GEOMETRYCOLLECTION(EMPTY)',
>> yoursridhere) )
>> (your number 2 doesn't work because that is the aggregate form, not
>> because ST_Union can't handle geometry collections I think)
>> Hope that helps,
>> Regina
>> *From:* postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
>> *Düster Horst
>> *Sent:* Wednesday, April 23, 2008 2:25 AM
>> *To:* postgis-users
>> *Subject:* [postgis-users] Geometrycollection to Multipolygon
>> I do have a Geometrycollection which consists of a collection of
>> Multipolygons and Polygons. My aim is to create one single
>> Multipolygon from the mentioned Geometry collection.
>> Until now I tried the following steps without result:
>> 1. ST_BUFFER(GEOMCOLL,0.0) => It works but all inner rings of my
>> input geometry are lost.
>> 2. ST_UNION(GEOMCOLL) => doesn't work with Geometrycollections
>> Does anyone has a solution to solve my problem?
>> Best regards
>> Horst
>> Dr. Horst Düster
>> Kanton Solothurn
>> SO!GIS Koordination
>> Rötistrasse 4
>> CH-4501 Solothurn
>> *The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended solely for the
>> addressee. If you received this in error, please contact the sender
>> and delete the material from any computer. *
>> * Help make the earth a greener place. If at all possible resist
>> printing this email and join us in saving paper. *
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
