[postgis-users] Re: "Summarizing" a collection of geometries
Kevin Neufeld
kneufeld at refractions.net
Fri Apr 25 21:58:48 PDT 2008
Hi Reid,
ST_Buffer(geometry, double) will expand a geometry by some specified
distance, creating a new larger geometry. I don't think this is the
effect you are after - creating simplified geometries that are quicker
to load at a larger zoom scales.
I would recommend that you break your MultiPolygons into individual
Polygons. If this is just for viewing purposes, at a large scale, you
may find that polygons with small areas are insignificant and could be
converted into point geometries. Further, I would run your Geometries
through ST_Simplify, which will reduce the number of vertices by some
specified tolerance using the Douglas-Peuker algorithm. Keep in mind
that ST_Simply does not enforce geometry validity, so you may have to
check for that afterwards. (ST_SimplifyPreserveTopology() has been know
to return invalid geometries as well). Alternatively, depending on what
you want for summarized geometries, you could take a convexhull of your
individuals Polygons as a "rough" approximation to their location.
In this way, a user can zoom to an area with a number of Points, and as
they zoom in the Points would change to simplified Polygons of various
tolerances, then eventually to your original complete Polygons.
-- Kevin
> Hi Kevin,
> Thanks for the note.
> The use case is basically indicating to users where they might like to
> zoom in if they want to see more details. So, the summary doesn't need
> to accurately represent the summarized geometries, just show roughly
> where they are.
> They will be seeing the summaries from scales of about 1 meter/128
> pixels up to 1 meter/8 pixels. Above this scale we show the actual
> geometry.
> The summaries will be fetched as vectors, not rasters.
> Did this scheme seem reasonable?
>> 1. Use ST_Buffer() to compute polygon buffers around members of the
>> collection. Question: ST_Buffer() docs say it can't handle
>> GeometryCollections. What about e.g. MultiPoint or MultiPolygon?
>> 2. Take the ST_Union() of the result of #1, producing a MultiPolygon.
> Thanks,
> Reid
> postgis-users mailing list
