[postgis-users] JSON
Courtin Olivier
olivier.courtin at camptocamp.com
Fri Aug 1 03:41:39 PDT 2008
On Aug 1, 2008, at 12:20 PM, Sophie GRAS wrote:
Hi Sophie,
> i want to use the asgeojson function.
> Do you know where we can find the 1.3.4 version of postgis ?
This version is not yet released,
You could use the current SVN version from 1.3 branch:
svn checkout http://svn.refractions.net/postgis/branches/1.3 postgis-1.3
(require to have an svn client already installed, cf http://subversion.tigris.org/)
> once you have your data in the "geojson format", how do you "call"
> it in the json file ?
Not sure to really understand the question, below a working use case:
SELECT ST_AsGeoJson(the_geom) FROM your_table LIMIT 1;
and copy/paste the result in OpenLayers:
cf <http://openlayers.org/dev/examples/vector-formats.html>
HTH,
Olivier
