[postgis-users] Merge all polygons from a dataset
Obe, Regina robe.dnd at cityofboston.gov
Mon Aug 4 05:47:53 PDT 2008
That is a little odd.  What are you using to view the data.  I know for
example QuantumGIS leaves out some geometries (particularly when they
are large geometries) unless you change some setting on it.  I noticed
this once when I loaded up a large Candadian dataset and thinking -
THATS CANADA.  Then I changed some setting and all looked fine.
With ST_Collect you probably get more geometries in your MULTIPOLYGON
than ST_Union since it won't dissolve the boundaries, but you shouldn't
be getting any geometries left out.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
danny
Sent: Monday, August 04, 2008 8:24 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Merge all polygons from a dataset
Thanks Regina.
For some reason ST_Collect doesn't give exactly the same result. For
example I'm trying to merge european countries in one shape and with
ST_Collects it omits England and other islands while ST_Union includes
them.
Anyway, my union finished after 4 hours.
I'm joining two tables on an ST_Intersect, one of which has ~15000
features (polygons) and the other just one (a complex polygon). The
query's been running for two hours... I hope I'll see the end of it
before the end of the day! (I've set the indexes where I could and tuned
PostgreSQL)
Regards.
On Mon, Aug 4, 2008 at 12:25 PM, Obe, Regina <robe.dnd at cityofboston.gov>
wrote:
	Try the trick documented here
http://postgis.refractions.net/documentation/manual-svn/ST_Collect.html
	On hindsight - I realized the ST_Multi call here is probably
unnecessary so you can leave that part out.
	Hope that helps,
	Regina
danny
	Sent: Monday, August 04, 2008 5:04 AM
	I'm getting very long processing time from ST_Union (on a shape
of europe at 1/100000 it's been running since 2 hours and hasn't
finished yet; on my previous one of 1/1000000 it took ~1 hour)
	Any other alternative and quicker ways to accomplish the same
operation?
	I just executed st_buffer(st_collect(the_geom)) but still
waiting. Should it take as long? ST_Collect by itself executes fast but
it's result violates the geometry check constraint.
	On Fri, Aug 1, 2008 at 5:31 PM, danny <whatevar89 at gmail.com>
wrote:
		Thanks Robert.
		I actually exported from ogr2ogr and it created a shape
that worked fine in ArcView.
		Best
		On Fri, Aug 1, 2008 at 5:19 PM, Burgholzer,Robert
<rwburgholzer at deq.virginia.gov> wrote:
			Could ArcView perhaps want some columns other
than just the shape?  Perhaps you could put a numeric ID or something
else in there.
			Just a thought,
			Robert W. Burgholzer
			Surface Water Modeler
			Office of Water Supply and Planning
			Virginia Department of Environmental Quality
			804-698-4405
			Open Source Modeling Tools:
			http://sourceforge.net/projects/npsource/
			-----Original Message-----
danny
			Sent: Friday, August 01, 2008 9:30 AM
from a dataset
			Many thanks, Regina! Indeed ST_Union generated
the polygon, invisible in PgAdmin!!
			It creates a nice layer when I open it in uDig.
			However when I export it with pgsql2shp, the
shape is unreadable by ArcView with the errmsg: Number of shapes does
not match the number of table records.
			Here's how I created the layer:
			create table europe_contour();
			SELECT addgeometrycolumn('db, 'europe_contour',
'the_geom', 32767,'MULTIPOLYGON', 2 );
			insert into europe_contour(the_geom) values(
(select st_union(the_geom) from europe));
			Then I generate the shapefile:
			"c:\Program
Files\PostgreSQL\8.3\bin\pgsql2shp.exe" -u postgres -P password -f
europe_contour db europe_contour
			Any suggestions perhaps on anything I've wrong?
			On Fri, Aug 1, 2008 at 1:15 PM, Obe, Regina
<robe.dnd at cityofboston.gov> wrote:
			Erik,
			How were you using ST_Union and what exactly do
you mean by no result.  no result as it looks blank?  If you are using
something like PgAdmin III - it will look blank because it exceeds the
buffer supported by PgAdmin III.
			SELECT the_geom is null
			FROM (somequery or table) as foo
			LIMIT 1
			will tell you if its actually returning no
geometry
			Hope that helps,
			Regina
danny
			Sent: Friday, August 01, 2008 6:12 AM
			To: postgis-users at postgis.refractions.net
			Subject: [postgis-users] Merge all polygons from
a dataset
			Hello everybody,
			I've converted a shapefile of Europe to PostGIS.
I would like to merge all the countries together so that I only have one
polygon left, the whole contour of Europe. I have tried ST_Union that
gives me no result. I've tried several other functions to no avail. Does
anybody know how I should proceed?
			Many thanks,
			Erik
			The substance of this message, including any
attachments, may be confidential, legally privileged and/or exempt from
disclosure pursuant to Massachusetts law. It is intended solely for the
addressee. If you received this in error, please contact the sender and
delete the material from any computer.
			Help make the earth a greener place. If at all
possible resist printing this email and join us in saving paper.
			postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
	The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure pursuant
to Massachusetts law. It is intended solely for the addressee. If you
received this in error, please contact the sender and delete the
	Help make the earth a greener place. If at all possible resist
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080804/8bf4c97d/attachment.html>
