[postgis-users] problem to transform coordinates
Guido Lemoine
guido.lemoine at jrc.it
Mon Aug 4 08:32:16 PDT 2008
Looks like you're mapping around the South Pole. The coordination
transform to 4326 there is going to be very inaccurate (question of the
week: what is the lat lon coordinate of the South Pole itself?)
http://www.uwgb.edu/DutchS/FieldMethods/UTMSystem.htm
suggest you should use "Polar Stereographic" rather than UTM in polar
regions (EPSG=32761 for the South Pole). But this may be small comfort
to you.
GL
Felipe Fedel Pinto wrote:
> SELECT ST_AsText(coord_22523)
> FROM coordsformiga limit 2;
> return:
> st_astext
> POINT(7650.676 500.29)
> POINT(7624.401 592.751)
> (2 rows)
> SELECT ST_AsText(ST_Transform(coord_
> 22523, 4326))
> return:
> st_astext
> POINT(140.139757378998 -89.9975973774248)
> (2 rows)
> SELECT postgis_full_version();
> POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
> 2007" USE_STATS
> (1 row)
> On Mon, Aug 4, 2008 at 10:20 AM, Obe, Regina
> <robe.dnd at cityofboston.gov <mailto:robe.dnd at cityofboston.gov>> wrote:
> Felipe Fedel,
> Can you send a sample of your data - results of the 2 queries below
> -- and result you get when you do
> SELECT ST_AsText(ST_Transform(coord_22523, 4326))
> Also what does
> give
> Only thought I have that could be wrong is your coordinates are not
> really 22523 or there is a problem with your proj 4 install. The above
> queries should pinpoint that.
> Hope that helps,
> Regina
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net
> <mailto:postgis-users-bounces at postgis.refractions.net>
> [mailto:postgis-users-bounces at postgis.refractions.net
> <mailto:postgis-users-bounces at postgis.refractions.net>] On Behalf Of
> Felipe Fedel Pinto
> Sent: Monday, August 04, 2008 9:27 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] problem to transform coordinates
> it also happens when I use ST_Transform and return the same thing from
> SELECT proj4text FROM spatial_ref_sys WHERE srid = 22523;
> Do you have another idea??
> Thanks!!!!
> Felipe Fedel
> On Thu, Jul 31, 2008 at 1:13 AM, Paragon Corporation <lr at pcorp.us
> <mailto:lr at pcorp.us>>
> wrote:
> Maybe there is something wrong with your entry in the
> spatial_ref_sys table for that SRID. Also provide two sample 22523
> points and what the ST_Transform looks like.
> Also please use ST_Transform if you are using a PostGIS install
> > 1.2
> What does
> SELECT proj4text
> WHERE srid = 22523
> give you?
> Mine gives
> +proj=utm +zone=23 +south +ellps=intl
> +towgs84=-206,172,-6,0,0,0,0 +units=m +no_defs
> Hope that helps,
> Regina
> Felipe Fedel Pinto
> Sent: Wednesday, July 30, 2008 7:26 PM
> To: postgis-users at postgis.refractions.net
> <mailto:postgis-users at postgis.refractions.net>
> Subject: [postgis-users] problem to transform coordinates
> To transform coordinates in PostGis I use the followed
> function:
> UPDATE <table> SET <new_geometry_column> =
> transform(<original_geometry_column>,<new_SRID>);
> I have been having a weird problem when I try to transform
> coordinates that are in a SRID=22523.
> Ex: I have to transform them to a SRID=4326
> UPDATE coordsformiga SET coord_4326 =
> transform(coord_22523,4326);
> where coordsformiga is the table,
> coord_22523 is the original geometry column with the
> coordinates in a SRID=22523
> coord_4326 I'd be the geometry column with the
> coordinates transformed in a SRID=4326
> the problem is:
> After the function, in the geometry column (coord_4326), all of
> the 97 coordinates have the same values.
> But it's happening only with a SRID=22523.
> Anybody knows what is happening??
> thanks
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
Guido Lemoine
Joint Research Centre, European Commission
Institute for the Protection and Security of the Citizen (IPSC)
Support to External Security
Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
WWW: http://ses.jrc.it
Disclaimer:
Views expressed are those of the individual and do not represent
the views of the European Commission
