[postgis-users] filing the holes in the swiss cheese?
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Wed Aug 6 12:08:19 PDT 2008
Thanks Paul, but this gives me no records at all.
BTW - the dirty secret exposed by the lack of ST_ is that I am running
an older version of PostgreSQL/PostGIS - 8.2 with posstgis_version():
1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
I wonder if there is some problem that this version has?
r.b.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, August 06, 2008 2:16 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] filing the holes in the swiss cheese?
try
select b.poli1 as fips, b.name, a.poli1 as contained_by_fips, a.name
from poli_bounds as a , poli_bounds as b
where a.poli1 <> b.poli1
and st_contains(a.the_geom, st_pointonsurface(b.the_geom))
and a.projectid = 1
and b.projectid = 1;
that should rid you of the boundary conditions plaguing st_contains.
P.
ps - note the "modern" st_contains(), with implicit index call.
On Wed, Aug 6, 2008 at 8:19 AM, Burgholzer,Robert
<rwburgholzer at deq.virginia.gov> wrote:
> I am trying to do a query of cities that are contained by counties (in
> Virginia, US), so that I can have a list that cross-references by FIPS
these
> relationships.
> My query looks like this:
> where a.poli1 <> b.poli1 and a.the_geom && b.the_geom
> and contains(convexhull(a.the_geom), b.the_geom)
> and a.projectid = 1
> This works fairly well, but omits a handful of cities that are most
> definitely within the boundaries of the county.
> Is "convexhull()" the correct function for this? Are my geometries
goofed
> up?
> Thanks!
> 804-698-4405
> postgis-users mailing list
