[postgis-users] I need to select all featcher touch one polygon
Fred Lehodey
lehodey at gmail.com
Thu Aug 7 12:15:18 PDT 2008
try this:
select b.* from "public"."IGFPLAN" as a,"public"."IGFPLAN" as b
where (a.the_geom && b.the_geom) and (a.gid = 2) and (b.gid != 2)
and distance(a.the_geom,b.the_geom) = yourValue;
Set yourValue = 0 for "touch polygon"
Is that help?
Fred.
On Thu, Aug 7, 2008 at 6:55 PM, eehab hamzeh <eehab40 at hotmail.com> wrote:
> Hello every body,
> can any body help me to write sql statment that select all the polygons
> that touch polygon in the same feature class.
> i try to do it in as below and find all polygon that are within 100 m from
> the polygon 2.
> SELECT the_geom FROM "public"."IGFPLAN"
> WHERE "Id" = '2' and distance(the_geom, the_geom) < 100
> Thanks
> ihab
> > From: postgis-users-request at postgis.refractions.net
> > Subject: postgis-users Digest, Vol 70, Issue 6
> > To: postgis-users at postgis.refractions.net
> > Date: Wed, 6 Aug 2008 12:01:19 -0700
> > Send postgis-users mailing list submissions to
> > To subscribe or unsubscribe via the World Wide Web, visit
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > or, via email, send a message with subject or body 'help' to
> > You can reach the person managing the list at
> > postgis-users-owner at postgis.refractions.net
> > When replying, please edit your Subject line so it is more specific
> > than "Re: Contents of postgis-users digest..."
> > Today's Topics:
> > 1. Newbie Question (Adam Vande More)
> > 2. Re: ST_Intersects (Paul Ramsey)
> > 3. Re: Newbie Question (Pedro Doria Meunier)
> > 4. Re: Newbie Question (Paul Ramsey)
> > 5. Re: Newbie Question (Pedro Doria Meunier)
> > 6. Update Error (Donald Ijams)
> > 7. RE: Update Error (Obe, Regina)
> > 8. Still cannot display postgis layers using ms4w
> > (kreshna_iceheart at yahoo.com)
> > 9. RE: Still cannot display postgis layers using ms4w
> > (Paragon Corporation)
> > 10. RE: Still cannot display postgis layers using ms4w< br>> (
> > 11. Configuration and getting started issues (Khavindra Sivenandan)
> > 12. area calculation problem (danny)
> > 13. filing the holes in the swiss cheese? (Burgholzer,Robert)
> > 14. Re: filing the holes in the swiss cheese? (Paul Ramsey)
> > Message: 1
> > Date: Tue, 05 Aug 2008 14:24:44 -0500
> > From: Adam Vande More <adam at imedmobility.com>
> > Subject: [postgis-users] Newbie Question
> > Message-ID: <4898A8FC.40201 at imedmobility.com>
> > Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> > Hello,
> > Perhaps my questions were addressed earlier or in some documentation I
> > missed. If so, I apologize in advance as I am completely new to GIS and
> > PostGIS. Judging f rom the documentation I have read, my needs are
> > extremely simple vs PostGIS capabilities however I am unsure if the
> > functionality of what I want actually exists.
> > I deal with areas in the US, territories that are regional in nature but
> > not bounded by common things eg state lines, water ways, counties, etc.
> > They are irregular shapes of varying land area. I also have sets of
> > latitude and longitude points. I would like some type of system where I
> > enter in a perimeter of territories, and find out whether a particular
> > latitude and longitude point lies within that perimeter.
> > My understanding of this is that I would need to either manually create
> > a GML type file with the perimeters in it, or use some type of map
> > authoring software to accomplish this goal. Are my understandings
> > correct and if so is there a recommendation for a particular piece of
> > software which can fulfill this?
> > Also, are the libraries/functions available for determining whether a
> > point is in a perimeter?
> > Much appreciated,
> > Adam Vandemore
> > Systems Administrator
> > IMED Mobility
> > (605) 498-1610
> > Message: 2
> > Date: Tue, 5 Aug 2008 12:39:30 -0700
> > From: "Paul Ramsey" <pramsey at cleverelephant.ca>
> > Subject: Re: [postgis-users] ST_Intersects
> > To: pcreso at pcreso.com, "PostGIS Users Discussion"
> > <postgis-users at postgis.refractions.net>
> > Message-ID:
> > <30fe546d0808051239v54067bcw6335074fe89d2fa6 at mail.gmail.com>
> > At core, this is not an indexing problem (of the usual sort). When we
> > can fix the memory leaks on the preparedgeometry code, and get it out
> > to users, it will make this case go much much faster, but until then,
> > it's going to be slow.
> > P.
> > On Tue, Aug 5, 2008 at 11:47 AM, <pcreso at pcreso.com> wrote:
> > > Hi Danny,
> > > As a maritime PostGIS user I have had issues with large & complex
> polygons/multipoygons in PostGIS (& GEOS), but not to the extent you seem
> to.
> > > I'm not an expert at this, but here are some things you might try.
> > > It looks like it is not using the index on sites, perhaps because
> postgres is applying a conversion to text for your constant & the attribute.
> Can you try modifying your SQL to
> > > .... where a.sitecode = 'xxxx'::<same spec as the sitecode column>
> > > (eg: where a.sitecode = 'xxxx'::varchar(10) if sitecode is varchar(10)
> > > To see if that enables the index to work better.
> > > Alternatively, perhaps you could create a new index on a
> (sitecode::text)
> > > Though I'm not sure if that's possible....
> > > Where I have large complex polygons, I have found tiling them really
> enables the spatial index to become useful. I generate a grid in postgis,
> build a table of the intersections of the grid & base layer & query against
> that.
> > > Essentially an index helps with long (deep) tables, ie, lots of small
> records, much more than fat (broad) tables, ie, few large records. Tiling
> geometries converts fat to deep, making things much faster.
> > > Cheers,
> > > Brent Wood
> > > --- On Tue, 8/5/08, danny <whatevar89 at gmail.com> wrote:
> > >> From: danny <whatevar89 at gmail.com>
> > >> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net
> > >> Date: Tuesday, August 5, 2008, 11:14 PM
> > >> Guido, it's a bufferzone around the contour of europe.
> > >> On Tue, Aug 5, 2008 at 1:02 PM, Guido Lemoine
> > >> <guido.lemoine at jrc.it> wrote:
> > >> > Erik,
> > >> > I don't know why european_waters would be a single
> > >> complex polygon?
> > >> > Do you mean it is a MULTIPOLYGON in Postgis? If so, it
> > >> is easy to
> > >> > break it apart in single polygons. If it includes
> > >> rivers, I can't imagine
> > >> > why it
> > >> > is a polygon in the first place. I would expect a
> > >> LINESTRING (or
> > >> > MULTILINESTRING in your case).
> > >> > This explains, of course, w hy performance is not much
> > >> improved. The &&
> > >> > operation does not really affect that.
> > >> > GL
> > >> > danny wrote:
> > >> >> Thanks Guido!
> > >> >> The sample you gave performed slightly better: 304
> > >> seconds. I'll still
> > >> >> have to wait a few months to let it run on all my
> > >> data though. Yes, sitecode
> > >> >> has a "normal" index, not a spatial one.
> > >> Both the_geom's have spatial ones.
> > >> >> The european_waters polygon is one single complex
> > >> polygon, scale 1/100000.
> > >> >> What's annoying is that when I do an intersect
> > >> in Arc View it's almost
> > >> >> instantaneou s. Of course I don't get exaclty
> > >> what I wan't but with some
> > >> >> tweaking I can maybe get closer. That would be a
> > >> great disappointment
> > >> >> though. I was really looking forward to using
> > >> ST_Within intensively!
> > >> >> Thanks Jean David, no performance gain though by
> > >> using it in the WHERE
> > >> >> clause, where I intended to use it in the first
> > >> place. I put it in the
> > >> >> Select for testing purposes.
> > >> >> explain select sitecode from sites a,
> > >> europe_waters b
> > >> >> where st_intersects(a.the_geom,b.the_geom) and
> > >> a.sitecode = 'xxxx';
> > >> >> "Nested Loop (cost=0.00..461.71 rows=1
> > >> width=10)"
> > >> >&g t; " Join Filter: _st_intersects(a.the_geom,
> > >> b.the_geom)"
> > >> >> " -> Seq Scan on sites a
> > >> (cost=0.00..453.43 rows=1 width=35764)"
> > >> >> " Filter: ((sitecode)::text =
> > >> 'xxxx'::text)"
> > >> >> " -> Index Scan using idx_europe_waters
> > >> on europe_waters b
> > >> >> (cost=0.00..8.27 rows=1 width=32)"
> > >> >> " Index Cond: (a.the_geom &&
> > >> b.the_geom)"
> > >> >> " Filter: (a.the_geom &&
> > >> b.the_geom)"
> > >> >> On Tue, Aug 5, 2008 at 10:53 AM, Guido Lemoine
> > >> <guido.lemoine at jrc.it<mailto:
> > >> >> guido.lemoine at jrc.it>> wrote:
> > >> >> Erik
> > >&g t; >>
> > >> >> Try this, and see if it is any faster:
> > >> >> select st_intersects(a.the_geom,b.the_geom)
> > >> from sites a,
> > >> >> europe_waters b where a.the_geom &&
> > >> b.the_geom and
> > >> >> I guess you mean that sitecode is indexed (not
> > >> spatially indexed),
> > >> >> because it seems to be a varchar.
> > >> >> Both a and b should have a spatial index on
> > >> the_geom, but I reckon
> > >> >> that is already the case. Also,
> > >> >> b (europe_layer) should not be a single
> > >> polygon, but rather a set
> > >> >> of polygons.
> > >> >> This is lesson 1 in the PostGIS tutor ial, more
> > >> or less. In return
> > >> >> for my 2 minutes effort, you are
> > >> >> obliged to report the new performance report,
> > >> so that future users
> > >> >> will benefit.
> > >> >> After all, I just saved you half a year...
> > >> >> GL
> > >> >> danny wrote:
> > >> >> Hello,
> > >> >> I'm wondering if it's normal to
> > >> have a 420 second response
> > >> >> time for the following query.
> > >> >> A spatial index has been set on the spatial
> > >> field (the_geom)
> > >> >> and other important fields (like sitecode).
> > >> I've g enerously
> > >> >> tweaked the memory options for postgresql.
> > >> >> With such a response time I would have to
> > >> let my query run for
> > >> >> half a year before getting the answer
> > >> I'm interested in! :)
> > >> >> Anybody know how I can boost up the process
> > >> or is it doomed to
> > >> >> always be so slow? The europe_layer is
> > >> indeed a complex
> > >> >> polygon....
> > >> >> select
> > >> st_intersects(a.the_geom,b.the_geom) from sites a,
> > >> >> europe_waters b where a.sitecode =
> > >> 'xxxx';
> > >> >> "Nested Loop (cost=0.00..496.18
> > >> rows=1310 width=35786)"
> > >> >> width=35754)"
> > >> 'xxxx'::text)"
> > >> >> " -> Seq Scan on europe_waters b
> > >> (cost=0.00..23.10
> > >> >> rows=1310 width=32)"
> > >> >> My true objective would be to join thses
> > >> two tables through an
> > >> >> st_intersects but for the time it is
> > >> unconceivable.
> > >> >> Many thanks,
> > >> >> Erik
> > >> _________________________________________ ______
> > >> <mailto:postgis-users at postgis.refractions.net>
> > >> >> Guido Lemoine
> > >> >> Joint Research Centre, European Commission
> > >> >> Institute for the Protection and Security of
> > >> the Citizen (IPSC)
> > >> >> Support to External Security
> > >> >> Via E. Fermi, 2749 TP 267 Ispra 21027 (VA),
> > >> Italy
> > >> >> Tel. +39 0332 786239 (direct line) Fax. +39
> > >> 0332 785154
> > >> >> WWW: http://ses.jrc.it
> > >> >> Disclaimer:
> > >> >> Views expressed are those of the individual and
> > >> do not represent
> > >> >> the views of the European Commission
> > >> >> _______________________________________________
> > >> > Guido Lemoine
> > >> > Institute for the Protection and Security of the
> > >> Citizen (IPSC)
> > >> > Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
> > >> > Tel. +39 0332 786239 (direct line) Fax. +39 0332
> > >> 785154
> > >> > WWW: http://s es.jrc.it
> > >> > Disclaimer:
> > >> > Views expressed are those of the individual and do not
> > >> represent the views
> > > postgis-users m ailing list
> > Message: 3
> > Date: Tue, 05 Aug 2008 20:45:01 +0100
> > From: Pedro Doria Meunier <pdoria at netmadeira.com>
> > Subject: Re: [postgis-users] Newbie Question
> > To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> > Message-ID:
> > <1217965501.4389.8.camel at 213-190-214-90-cmts01.netmadeira.com>
> > Content-Type: text/plain; charset="us-ascii"
> > Hi Adam,
> > This is what I use when I want to see which map to use for a vehicle's
> > current position:
> > SELECT myfield1 FROM maps AS m
> > WHERE m.b_box && geomfromtext('POINT(-16.3 32.7)',4326) LIMIT 1
> > (Note: there might be a newer/better function in PostGIS 1.3 ... )
> > The top-level maps table consists of polygons defining countries
> > boundaries.
> > This query returns the correspondent map for the given location so this
> > should be applicable for your perimeters, which I guess are polygons :)
> > HTH,
> > Pedro Doria Meunier
> > On Tue, 2008-08-05 at 14:24 -0500, Adam Vande More wrote:
> > > Hello,
> > > PostGIS. Judging from the documentation I have read, my needs are
> but
> > > not bounded by common things eg state lines, water ways, countie s,
> etc.
> > > Much appreciated,
> > -------------- next part --------------
> > A non-tex t attachment was scrubbed...
> > Name: not available
> > Type: application/pgp-signature
> > Desc: This is a digitally signed message part
> > Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080805/356f2fed/attachment-0001.bin
> > Message: 4
> > Date: Tue, 5 Aug 2008 12:46:14 -0700
> > To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> > Message-ID:
> > <30fe546d0808051246p6386bee5u2877020e9392a36d at mail.gmail.com>
> > Well, that's the opposite of the usual point-in-polygon use case
> > (given an existing set of polygons and a point input, tell me what
> > polygons it falls within), but it's equally tractable.
> > You need an input interface, and that will be the hardest part of your
> > task. You can do something in Google Maps, if you like, then stuff the
> > geometry down into a script (php, asp, whatever) that in turn
> > inscribes it into a SQL statement ala:
> > select points.id, points.name from points where
> > st_contains('POLYGON(....)', points.geometry);
> > Where the 'POLYGON(...)' is constructed by your script from your user
> > interface input.
> > Enjoy,
> > P.
> > On Tue, Aug 5, 2008 at 12:24 PM, Adam Vande More <adam at imedmobility.com>
> wrote:
> > > Hello,
> extremely
> > > simple vs PostGIS capabilit ies however I am unsure if the
> functionality of
> but not
> They
> > > are irregular shapes of varying land area. I also have sets of latitude
> and
> > > longitude points. I would like some type of system where I enter in a
> > > perimeter of territories, and find out whether a particular latitude
> and
> a
> authoring
> > > software to accomplish this goal. Are my understandings correct and if
> so
> > > is there a recommendation for a particular piece of software which can
> > > fulfill this?
> & gt; > Also, are the libraries/functions available for determining whether
> a point
> > > is in a perimeter?
> > > Much appreciated,
> > > Adam Vandemore
> > > IMED Mobility
> > > (605) 498-1610
> > Message: 5
> > Date: Tue, 05 Aug 2008 20:57:39 +0100
> > Message-ID:
> > <1217966259.4389.12.camel at 213-190-214-90-cmts01.netmadeira.com> ;
> > Shame on me... I should have read Adam's question more attentively ...
> > Adam:
> > Paul is absolutely right.
> > Regards,
> > Pedro Doria Meunier
> > > st_contains('POLYGON(....)', poi nts.geometry);
> > > interface input.
> > > Enjoy,
> > > P.
> adam at imedmobility.com> wrote:
> > > > Hello,
> I
> and
> extremely
> functionality of
> but not
> They
> latitude and
> and
> create a
> authoring
> if so
> can
> > > > fulfill this?
> point
> > > > is in a perimeter?
> > > > Much appreciated,
> > > > Adam Vandemore
> > > > IMED Mobility
> > > > (605) 498-1610
> > A non-text attachment was scrubbed...
> > Name: not available
> > Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080805/98ad00f1/attachment-0001.bin
> > Message: 6
> > Date: Tue, 05 Aug 2008 15:00:35 -0700
> > From: Donald Ijams <dsijams at gmail.com>
> > Subject: [postgis-users] Update Error
> > Message-ID: <4898CD83.6070704 at gmail.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > When I attempt to update a geometry column from a field in another table
> > with:
> > UPDATE recent
> > SET xypoint = ST_GeomFromText((raw.x, raw.y),102249)
> > from raw
> > where recent.casenum=raw.casenum;
> > I get:
> > *SQL error:*
> > ERROR: function st_geomfromtext(record, integer) does not exist
> > LINE 3: xypoint = ST_GeomFromText((raw.x, raw.y),102249)
> > HINT: No function matches the given name and argument types. You might
> need to add explicit type casts.
> > Probably something simple, but I'm not seeing it.
> > Don
> > An HTML attachment was scrubbed...
> > URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080805/7f4711de/attachment-0001.html
> > Message: 7
> > Date: Tue, 5 Aug 2008 22:59:56 -0400
> > From: "Obe, Regina" <robe.dnd at cityofboston.gov>
> > Subject: RE: [postgis-users] Update Error
> > Message-ID:
> > <53F9CF533E1AA14EA1F8C5C08ABC08D20197A16F at ZDND.DND.boston.cob>
> > ST_GeomFromText takes the form ST_GeomFromText('POINT(' || raw.x || ' '
> || raw.y || ')', 102249)
> > Anyrate for point geometries its more efficient to use ST_MakePoin t so
> something like
> > UPDATE recent
> > SET xypoint = ST_SetSRID(ST_MakePoint(raw.x, raw.y),102249)
> > from raw
> > Hope that helps,
> > Regina
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net on behalf of Donald
> Ijams
> > Sent: Tue 8/5/2008 6:00 PM
> > with:
> > UPDATE recent
> > from raw
> > I get:
> > *SQL error:*
> > Don
> > The substance of this message, including any attachments, may be
> > confidential, legally privileged and/or exempt from disclosure
> > pursuant to Massachusetts law. It is intended
> > solely for the addressee. If you received this in error, please
> > contact the sender and delete the material from any computer.
> > URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080805/61d5ef9c/attachment-0001.html
> > Message: 8
> > Date: Wed, 6 Aug 2008 00:17:05 -0700 (PDT)
> > From: "kreshna_iceheart at yahoo.com" <kreshna_iceheart at yahoo.com>
> > Subject: [postgis-users] Still cannot display postgis layers using
> > ms4w
> > Message-ID: <295797.42389.qm at web56101.mail.re3.yahoo.com>
> > Help. Somebody please help. Anybody. :-(
> > I am using postgreSQL 8.2.5 for Windows with postGIS. The database was
> installed using Windows .msi installation package. I am also using ms4w
> 2.2.7 that comes with MapServer 5.0.2. All installed on Windows XP Service
> Pack 2.
> > The MapServer does support postGIS. When I executed mapserv -v, I got the
> following:
> > MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPOR TS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > In the postgreSQL database, I have created a database named test_mapserv.
> I also created a schema named rencana, and a table named kawasanbencana. The
> name of the geometry column is the_geom.
> > I have created a spatial index (kawasanbencanaspix) on the geometry
> column. I also use lowercase to write the 'from' statement.
> > The problem is: MapServer always gives the "..Query error. Error
> executing POSTGIS DECLARE.." error message, no matter what I do. And I have
> tried everything ad nauseam.
> > I have tried specifying the DATA line without USING UNIQUE ... USING SRID
> line. I have tried specifying the DATA line with USING UNIQUE ...USING SRID.
> I have tried using double apostrophe (") and single apostrophe ('). It
> doesn't matter. Everything I have tried has failed, a nd I still get the
> error message no matter what I did.
> > My mapfiles are attached in this mail. Each reflect my futile attempt,
> and all of them generated the error message.
> > My first attempt:
> > This is my first attempt. I have both the mapfile and the error message
> attached on this mail.
> > CONNECTIONTYPE postgis
> > CONNECTION 'host=localhost user=rtrw password=123456 port=5432
> dbname=test_mapserver'
> > DATA 'the_geom from rencana.kawasanbencana'
> > And I got the following error message:
> > msDrawMap(): Image handling error. Failed to draw layer named
> 'kawasanbencana'. prepare_database(): Query error. Error executing POSTGIS
> DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR
> SELECT asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from
> rencana.kawasanbencana WHERE () and (the_geom && setSRID( 'BOX3D(528635
> .525378392 9074209,609092.162121608
> 9134520)'::BOX3D,find_srid('','rencana.kawasanbencana','the_geom') ))'
> Postgresql reports the error as 'ERROR: syntax error at or near ")" LINE 1:
> ...DR'),gid::text from rencana.kawasanbencana WHERE () and (the... ^ ' More
> Help: Error with POSTGIS data variable. You specified 'check your .map
> file'. Standard ways of specifiying are : (1) 'geometry_column from
> geometry_table' (2) 'geometry_column from (sub query) as foo using unique
> column name using SRID=srid#' Make sure you put in the 'using unique column
> name' and 'using SRID=#' clauses in. For more help, please see
> > http://postgis.refractions.net/documentation/ Mappostgis.c - version of
> Jan 23/2004.
> > My second attempt:
> > I tried adding USING UNIQUE to my DATA line. There is something odd with
> my spatial table though: whenever I view the data contents with pgAdmin, I
> can always see the oid column (first column to the left, before the PK
> column). However, I cannot find the oid column when viewing the table's
> column definition. The question is: does my table have oid column or not?
> And does it have something to do with the error?
> > Nonethless, here's my lines:
> > DATA 'the_geom from rencana.kawasanbencana using unique oid'
> > And I still get the same error message as above. The difference is that
> the error message now says 'oid' instead of 'gid'. For instance,
> "(the_geom)),'NDR'),gid" becomes "(the_geom)),'NDR'),oid", but everything
> else remains the same.
> > My third attempt:
> > Like I said in my second attempt, I'm not sure whether my table has oid
> column or not. Thus, in my third attempt I used the gid column instead,
> especially since the gid column is my primary key column anyway. This is my
> lines:
> > DATA 'the_geom from rencana.kawasanbencana using unique gid'
> > And I got exactly the same error message as my first attempt.
> > My fourth attempt:
> > In my fourth attempt, I used the gid column for my unique id, and I am
> using SRID=1. Here is the lines:
> > DATA 'the_geom from rencana.kawasanbencana using unique gid using SRID=1'
> > Well I still got the error message. This time, the error message is
> slightly different. Instead of getting "::BOX3D,find_srid", I got
> "::BOX3D,1".
> > Here is the complete error message:
> > msDrawMap (): Image handling error. Failed to draw layer named
> 'BOX3D(528635.525378392 9074209,609092.162121608 9134520)'::BOX3D,1) )'
> > Mappostgis.c - version of Jan 23/2004.
> > My fifth attempt:
> > Now I had been pretty much desperate, I just wrote using SRID=#, closed
> my eyes, and hoped for the best. Here's the lines:
> > DATA 'the_geom from rencana.kawasanbencana using unique gid using SRID=#'
> > I still get an error message. This time, the error message is different
> altogether. Here's the message:
> 'kawasanbencana'. msPOSTGISLayerParseData(): Query error. Error parsing
> POSTGIS data variable: You specified 'using SRID=#' but didnt have any
> numbers! More Help: Error with POSTGIS data variable. You specified
> 'the_geom from rencana.kawasanbencana using unique gid using SRID=#'.
> Standard ways of specifiying are : (1) 'geometry_column from ge
> Jan 23/2004.
> > I'm pretty much desperate. Could somebody please tell what's wrong on my
> mapfile? Or maybe ms4w just cannot display postGIS data? Do I need to
> install postGIS and MapServer on Linux, in order to get them work together?
> Please help. :-(
> > Thanks,
> > -Kresh
> > Type: application/octet-stream
> > Desc: not available
> > Url : http://lists.refractions.net/pipermail/postgis-users/attachments/20080806/ff428038/test_mapserv_01.dll
> > ions.net/documentation/ Mappostgis.c - version of Jan 23/2004.
> > Desc: not available
> > Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080806/ff428038/test_mapserv_02.bin
> SELECT asbinary(force_collection(force_2d(the_geom)),'NDR'),oid::text from
> 'BOX3D(528635.525378392 9074209,609092.16212 1608
> ...DR'),oid::text from rencana.kawasanbencana WHERE () and (the... ^ ' More
> > Desc: not available
> > Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080806/ff428038/test_mapserv_03.dll
> column name using SRID=srid#' Make sure you put in the 'using unique colu mn
> > Desc: not available
> > Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080806/ff428038/test_mapserv_04.bin
> > f Jan 23/2004.
> > Desc: not available
> > Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080806/ff428038/test_mapserv_05.dll
> > msDraw Map(): Image handling error. Failed to draw layer named
> Standard ways of specifiying are : (1) 'geometry_column from geometry_table'
> (2) 'geometry_column from (sub query) as foo using unique column name using
> SRID=srid#' Make sure you put in the 'using unique column name' and 'using
> Jan 23/2004.
> > Message: 9
> > Date: Wed, 6 Aug 2008 04:10:32 -0400
> > From: "Paragon Corporation" <lr at pcorp.us>
> > Subject: RE: [postgis-users] Still cannot display postgis layers using
> > ms4w
> > To: "'PostGIS Users Discussion'"
> > Message-ID: <001501c8f79b$e5fd1860$4d812e40 at l>
> > Just a guess. Get rid of your FILTER clause or actually put a where
> > condition in your FILTER clause. I think the fact that your FILTER clause
> > is empty is causing PostgreSQL to generate an invalid query that looks
> > something like this
> > SELECT *
> > FROM sometable
> > WHERE
> > Can't have where without a where condition.
> > Hope that helps,
> > Regina
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> > Sent: Wednesday, August 06, 2008 3:17 AM
> > Subject: [postgis-users] Still cannot display postgis layers using ms4w
> Service
> > Pack 2.
> > following:
> > SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> > In the postgreSQL database, I have created a dat abase named
> test_mapserv. I
> The
> column.
> executing
> > POSTGIS DECLARE.." error message, no matter what I do. And I have tried
> SRID.
> > doesn't matter. Everything I have tried has failed, and I still get the
> and
> > a ll of them generated the error message.
> > My first attempt:
> POSTGIS
> from
> > 9134520)'::BOX3D,find_srid('','rencana.kawasanben cana','the_geom') ))'
> 1:
> More
> column
> Jan
> > 23/2004.
> > My second attempt:
> my
> can
> > always see the oid column (first column to the l eft, before the PK
> column).
> > However, I cannot find the oid column when viewing the table's column
> > definition. The question is: does my table have oid column or not? And
> does
> the
> > My third attempt:
> > column or not. Thus, in my third attemp t I used the gid column instead,
> my
> > lines:
> > My fourth attempt:
> using
> > SRID=1'
> slightly
> > different. Instead of gett ing "::BOX3D,find_srid", I got "::BOX3D,1".
> POSTGIS
> from
> 1:
> More
> column
> > My fifth attempt:
> my
> > SRID=#'
> > POSTGI S data variable: You specified 'using SRID=#' but didnt have any
> geometry_table'
> using
> 'using
> Jan
> > 23/2004.
> together?
> > Please help. :-(
> > Thanks,
> > -Kresh
> > < br>>
> > Message: 10
> > Date: Wed, 6 Aug 2008 01:33:38 -0700 (PDT)
> > ms4w
> > Message-ID: <801791.19065.qm at web56103.mail.re3.yahoo.com>
> > Content-Type: text/plain; charset=us-ascii
> > Dear Regina....
> > YOU ARE CORRECT!!! I got rid of the empty FILTER clause and now the map
> is displayed properly! :-)
> > Many many many (times infinity) thanks!
> > -Kresh
> > --- On Wed, 8/6/08, Paragon Corporation <lr at pcorp.us> wrote:
> > > From: Paragon Corporation <lr at pcorp.us&g t;
> ms4w
> > > To: "'PostGIS Users Discussion'" <
> > > Date: Wednesday, August 6, 2008, 4:10 AM
> > > a where
> > > your FILTER clause
> > > that looks
> > > something like this
> > > SELECT *
> > > FROM sometable
> > > WHERE
> > > Hope that helps,
> > > Regina
> > > [mailto:postgis-users-bounces at postgis.refrac tions.net] On
> > > Behalf Of
> > > layers using ms4w
> > > database was
> > > also using ms4w
> > > Windows XP Service
> > > Pack 2.
> > > -v, I got the
> > > following:
> > > OUTPUT=WBMP
> > > SUPPORTS=GEOS
> > > INPUT=SHAPEFILE
> > > test_mapserv. I
> > > kawasanbencana. The
> > > geometry column.
> > > And I have tried
> > &g t; everything ad nauseam.
> > > ... USING SRID
> > > apostrophe ('). It
> > > I still get the
> > > futile attempt, and
> > > My first attempt:
> > > error message
> > > CONNECTION 'host=localhost user=rtrw< br>> > password=123456 port=5432
> > > named
> > > BINARY CURSOR FOR
> > > SELECT
> > > from
> > > setSRID(
> > > or near ")" LINE 1:
> > > 'check your .map
> > > help, please see
> > > - version of Jan
> > > 23/2004.
> > > My second attempt:
> > > something odd with my
> > > with pgAdmin, I can*> > always see the oid column (first column to the
> left, before
> > > the PK column).
> > > table's column
> > > or not? And does
> > > unique oid'
> > > difference is that the
> > > My third attempt:
> > > my table has oid
> > > column instead,
> > > anyway. This is my
> > > lines:
> > > unique gid'
> > > attempt.
> > > My fourth attempt:
> > > In my fourth attempt, I used the gid column for my un ique
> > > id, and I am using
> > > unique gid using
> > > SRID=1'
> > > message is slightly
> > > named
> > > BINARY CURSOR FOR
> > > SELECT
> > > asbinary(force_collection(fo rce_2d(the_geom)),'NDR'),gid::text
> > > from
> > > setSRID(
> > > or near ")" LINE 1:
> > > 'check your .map
> > > help, please see
> > > http://postgis.refractions.net/documentation/> > Mappostgis.c -
> > > My fifth attempt:
> > > SRID=#, closed my
> > > unique gid using
> > > SRID=#'
> > > is different
> > > named
> > > POSTGIS data variable: You s pecified 'using SRID=#'
> > > but didnt have any
> > > specified
> > > using SRID=#'.
> > > - version of Jan
> > > 23/2004.
> > > what's wrong on my
> > > I need to
> > > install postGIS a nd MapServer on Linux, in order to get
> > > them work together?
> > > Please help. :-(
> > > Thanks,
> > > -Kresh
> > Message: 11
> > Date: Wed, 6 Aug 2008 16:04:32 +0200
> > From: Khavindra Sivenandan <khavindra at sefsa.co.za>
> > Subject: [postgis-users] Configuration and getting started issues
> > To: "postgis-users at postgis.refractions.net"
> > <postgis-users at postgis.refractions.n et>
> > Message-ID:
> > <1677E63198782240825AEF9E248718DE764FB4613E at sefsaserver.sefsa.local>
> > Hi There
> > I am new to PostGIS/PostgreSQL. Can somebody help me with the following
> support information.
> > I went as far as installing PostgreSQL & PostGIS. I require to configure
> the Geometry_Columns Table as in the manual. It is somewhat vague as to the
> inputs into the columns F_Table_Catalogue, F_Table_Schema & F_Table_Name. I
> have managed to sort out the other columns as indicated in the manual
> (4.2.2)
> > I have managed to connect to the database from various opensource desktop
> GIS software, but my database is not configured correctly. Is there any
> detailed material, other than the online manual I can look up or can
> somebody please help me to move on further from here. Ultimately, I would
> like to move data (shapefiles) into the database within some classification
> system (e.g. by Province, state, etc...) which can then be utilised by
> desktop and web users.
> > Thanks
> > Khavin Sivenandan
> > Khavindra at sefsa.co.za
> > URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080806/34cc54ab/attachment-0001.html
> > Message: 12
> > Date: Wed, 6 Aug 2008 16:06:14 +0200
> > Subject: [postgis-users] area calculation problem
> > Message-ID:
> > <5c218180808060706k3bdd3a0ar5db0e09c6da759cb at mail.gmail.com>
> > Hi, I have a problem.
> > I'm trying to calculate the area of a great number of si tes on a
> specific
> > territory.
> > The problem is that these sites can overlap (as they do very frequently)
> and
> > I do not want to count the same portion of land twice.
> > A st_union would work with this right? Unfortunately my experience with
> this
> > function is that it is way too slow for the numerous polygons I would
> have
> > to merge. As a matter fact it would take years.
> > Does anybody know of a hack around this? (In PostGIS or ArcGIS)
> > Many thanks!
> > URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080806/3ce94bd4/attachment-0001.html
> > Message: 13
> > Date: Wed, 6 Aug 2008 11:19:19 -0400
> > From: "Burgholzer,Robert" <rwburgholzer at deq.virginia.gov>
> > Subject: [postgis-users] filing the holes in the swiss cheese?
> &g t; To: "PostGIS Users Discussion" <
> > Message-ID:
> > <6C097DA58429B743A67070F98BE73A370379B67B at deqex01.deq.local>
> > I am trying to do a query of cities that are contained by counties (in
> > Virginia, US), so that I can have a list that cross-references by FIPS
> > these relationships.
> > My query looks like this:
> > select b.poli1 as fips, b.name, a.poli1 as contained_by_fips, a.name
> > from poli_bounds as a , poli_bounds as b
> > where a.poli1 <> b.poli1 and a.the_geom && b.the_geom
> > and contains(convexhull(a.the_geom), b.the_geom)
> > and a.projectid = 1
> > and b.projectid = 1;
> > This works fairly well, but omits a handful of cities that are most
> > definitely within the boundaries of the county.
> > Is "convexhull()" the correct function for this? Are my geometries
> > goofed up?
> > Thanks!
> > Robert W. Burgholzer
> > Surface Water Modeler
> > Office of Water Supply and Planning
> > Virginia Department of Environmental Quality
> > 804-698-4405
> > Open Source Modeling Tools:
> > http://sourceforge.net/projects/npsource/
> > URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20080806/1d85ac47/attachment-0001.html
> > Message: 14
> > Date: Wed, 6 Aug 2008 11:15:43 -0700> From: "Paul Ramsey" <
> > Subject: Re: [postgis-users] filing the holes in the swiss cheese?
> > Message-ID:
> > <30fe546d0808061115y273ba5b1xc178f9e3cd9f9c05 at mail.gmail.com>
> > try
> > and st_contains(a.the_geom, st_pointonsurface(b.the_geom))
> > and a.projectid = 1
> > that should rid you of the boundary conditions plaguing st_contains.
> > P.
> > ps - note the "modern" st_contains(), with implicit index call.
> > On Wed, Aug 6, 2008 at 8:19 AM, Burgholzer,Robert
> these
> > > relationships.
> > > and a.projectid = 1
> &g t; > Is "convexhull()" the correct function for this? Are my geometries
> goofed
> > > up?
> > > Thanks!
> > > 804-698-4405
> > < br>> _______________________________________________
> > End of postgis-users Digest, Vol 70, Issue 6
> Connect to the next generation of MSN Messenger Get it now!
> <http://imagine-msn.com/messenger/launch80/default.aspx?locale=en-us&source=wlmailtagline>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080807/0db917e6/attachment.html>
