[postgis-users] Upload a shapefile to PostGIS via Web?
Luigi Castro Cardeles luigi.cardeles at gmail.com
Wed Aug 13 10:51:56 PDT 2008
HI,
i think that you need to download the file (shp, dbf e shx) to some folder
and run (via shell script or something - using cron) the conversion. You
need some information about your shapefile (CRS, SRS etc), maybe the user
could pass that via form. I think that is the easy way. but if you have
problems with the conversion... you have think how to deal with that.
[]'s
2008/8/13 David Calle <davydky at gmail.com>
> Also you can select the origin of your data....  on your map file....
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080813/5897e35f/attachment.html>
