[postgis-users] Botswana SRID,ESPG,PROJ4
Bochengedu Somolekae
bochengedusomolekae at yahoo.com
Wed Aug 13 14:53:27 PDT 2008
Trying to create SRID,EPSG and PROJ4 for Botswana and don't know how, Data available:
PROJCS["PCS_BOTSWANA_BTRS_LO25",GEOGCS["GCS_Cape",DATUM["D_Cape",SPHEROID["Clarke_1880_Arc",6378249.145,293.466307656]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",0],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",25],PARAMETER["Scale_Factor",1],PARAMETER["Latitude_Of_Origin",0],UNIT["Meter",1]]
PROJCS["BTRS_PCS_UTM35S",GEOGCS["GCS_Clarke_1880_Arc",DATUM["D_Clarke_1880_Arc",SPHEROID["Clarke_1880_Arc",6378249.145,293.466307656]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000],PARAMETER["False_Northing",10000000],PARAMETER["Central_Meridian",27],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0],UNIT["Meter",1]]
find attached doc
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080813/f86760e5/attachment.html>
Type: application/msword
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080813/f86760e5/attachment.doc>
