[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Martin Davis
mbdavis at refractions.net
Thu Aug 14 15:03:00 PDT 2008
It's your bad luck to have geometries that make PostGIS fail... 8^)
If there's geometries which cause problems with certain operations, the
most helpful thing to do is to post them along with a description of the
problem. That gives a fighting chance to fix them when further
development is done.
So Java2D worked on your problem? I have to admit, I'm impressed how
robust Java2D is. If I could understand their algorithm I'd be keen on
trying to follow their approach to get the same level of robustness in
JTS/GEOS...
Bresnahan, Mike wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA256
> Welp, I think I have given up on trying to do the union inside PostGIS
> because I can't make it fast and reliable. Instead I have decided to use
> Java2D to perform the union. I ended up doing the same thing with
> Oracle. Both Oracle and PostGIS have been bad at doing CAG operations
> when compared to Java2D and ESRI ArcGIS. Is that just my bad luck or is
> there something fundamental going on here?
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
