[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Bresnahan, Mike Mike.Bresnahan at bestbuy.com
Thu Aug 14 16:00:37 PDT 2008
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
> It's your bad luck to have geometries that make PostGIS fail...   8^)
> If there's geometries which cause problems with certain operations,
the
> most helpful thing to do is to post them along with a description of
the
> problem.  That gives a fighting chance to fix them when further
> development is done.
The problem of ST_SimplifyPreserveTopology() producing geometries that
ST_Union() chokes on is already known. When I tried to scrub the
polygons I ran into performance problems, particularly with
ST_Union(geometry). I ran into similar performance problems with
Oracle's sdo_aggro_union().
> So Java2D worked on your problem?  I have to admit, I'm impressed how
> robust Java2D is.  If I could understand their algorithm I'd be keen
on
> trying to follow their approach to get the same level of robustness in
> JTS/GEOS...
Yes, Java2D was able to perform a union on the geometries produced by
ST_SimplifyPreserveTopology() and it does the union relatively fast.
The only thing I have found that beats Java2D is ArcGIS. In one test I
did I performed a union of the USGS state boundaries
(http://www.census.gov/geo/cob/bdy/st/st00shp/st99_d00_shp.zip). Here
are the results:
Oracle 11.1:	25 min
PostGIS 1.3.3:	42 sec
Java2D 1.5:		4 sec
ArcMap 9.2:		1 sec
Any thoughts why PostGIS is about 40x slower than ArcMap at this
operation?
Any thoughts why Oracle takes 25 min? lol
The bottleneck in my application now looks to be
ST_SimplifyPreserveTopology(). I'm finding that it's often best to do
computation outside the database. However, one thing that Java2D is
missing is a polygon simplification function. I might look to see if
Geotools has one.
-----BEGIN PGP SIGNATURE-----
Version: PGP Universal 2.8.3
Charset: us-ascii
wsBVAwUBSKS4Vh6WPRoYuvd0AQjehAf+LetIb4Q+xMXZZiPkJmT8rteWMPeDYPor
i31cLgjIvY1x7WZZ8V95rSnjYfpARlqbInxwjM4tXAz17kfOUJfnbMS13N/DDCDT
IxpHDuim3/HGDMweqP//GNMfpHwK5a8hPZeHlZrTvL62EOZ4F7gyzIJ3ZBkHMikS
KshFkiHfIyoThVXRHX9mdzEmQAR57zGKEid3S3Q97ESelbk8/GqSZB0PY6LYJ0xj
MLoHeAYDrKwNCSI2bHxXhtP4fSwGaN7KkZ6unzG/QOb6YOzxmSAx4/KE89KBCmnC
2yXCX8v3ONi8Vucti7lZ29DHDbE9Q6HP7wLeWnOtXKm/n8DoIlfhOw==
=BHDB
-----END PGP SIGNATURE-----
