[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Martin Davis mbdavis at refractions.net
Thu Aug 14 17:09:50 PDT 2008
Quite possibly...  at the moment Java's memory mngmt is beating out the
memory handling in GEOS.
Bresnahan, Mike wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA256
>> The original code for ST_SimplifyPreserveTopology comes from JTS.  You
>> can either use the library directly, or try JEQL for a command-line
>> interface to it.  You can find both at http://tsusiatsoftware.net/
> Ah ha, I see that now. Do you think the original version will run any
> faster?
> -----BEGIN PGP SIGNATURE-----
> Version: PGP Universal 2.8.3
> Charset: us-ascii
> wsBVAwUBSKTELh6WPRoYuvd0AQjpJwf+PsYBv2Ls0WPoxPamkUWYJP6e+JJX0xs2
> 4Fo6NPsmr661FfLTEHqxd4633pqiHIU7jEnaUrArazcCOrjas8tzqEmIGco2ovpD
> S6QgXghJs3qj0oy7NvToQOslbrZuo/Kmtj3cH6ASppYR9JJuMLpDG/mwMwPyliU0
> ak2l0RujcDhYpYz5+m9oxK5qj3rJG7cx/GUgQta3Rg8TX5KT/CgAJ6Giv0VWc1xj
> q9E/CGE89jC0EyGxd4XU3RUUDLbyCJK6bXL1aCqM7Op3Ri7QwfHuwsK3y9zUypr2
> E6xocfRrZgLZD4a5f9OvRYzbfxyY5yo2e4I5OaMBKJTT8Vlg/xkYlg==
> =m2D7
> -----END PGP SIGNATURE-----
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
