[postgis-users] asGML Error
Dane Springmeyer
blake at hailmail.net
Fri Aug 15 17:50:20 PDT 2008
Hi David,
I'm not sure about that error, but if you are exporting from postgis
to be able to be read into an OpenLayers map you can also use the WKT
format, as well as GeoJson and KML.
So, you are not web to GML.
Cheers,
Dane
On Aug 15, 2008, at 5:35 PM, David Calle wrote:
> Hi List,
> I need to convert my geometry to GPS position.... I'm trying with
> asgml(geometry)
> But I have this error.. ERROR: Only GML 2 and GML 3 are supported
> And this is my version of postgis..
> "POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
> 2007" USE_STATS DBPROC="0.3.0" RELPROC="1.3.3" (needs proc upgrade)"
> I need this, because I need to generate a xml file with the GPS
> format of my points...
> Thanks Advanced...!!
> postgis-users mailing list
