[postgis-users] asGML Error
Paragon Corporation lr at pcorp.us
Sat Aug 16 10:18:59 PDT 2008
David,
We've had this error before.  I think its because you didn't run the
lwpostgis_upgrade.sql script which should be located in
\share\contri\postgis of your postgresql install.  I think that was how we
fixed ours.
Note your version says RELPROC="1.3.3" (needs proc upgrade)"
Which means you are running the latest binaries but not the latest sql
functions.
Hope that helps,
Leo
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of David
Calle
Sent: Friday, August 15, 2008 8:36 PM
To: PostGIS Users Discussion
Subject: [postgis-users] asGML Error
Hi List,
I need to convert my geometry to GPS position.... I'm trying with
asgml(geometry)
But I have this error.. ERROR:  Only GML 2 and GML 3 are supported
And this is my version of postgis..
"POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS DBPROC="0.3.0" RELPROC="1.3.3" (needs proc upgrade)"
I need this, because I need to generate a xml file with the GPS format of my
points...
Thanks Advanced...!!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080816/6f35f971/attachment.html>
