[postgis-users] Convert multipolygons to separate polygons
Simon O'Malley
simonom at gmail.com
Tue Aug 19 16:53:13 PDT 2008
Hi Mike, Dane
Thanks for your responses. Dump worked a treat.
Teach me for not RTFM'ing.
Simon
On Wed, Aug 20, 2008 at 11:00 AM, Dane Springmeyer <blake at hailmail.net> wrote:
> Hi Simon,
> Yes,
> This is one approach:
> SELECT ST_PointOnSurface(ST_GeometryN(geometry, generate_series(1,
> ST_NumGeometries(geometry)))) AS single_geometry_turned_into_point
> FROM your_table;
> Cheers,
> Dane
> On Aug 19, 2008, at 3:46 PM, Simon O'Malley wrote:
>> Hi All
>> Is there a way to split multipolygons into separate polygon features?
>> Or is there a way to step through all the polygons in a multipolygon
>> and use pointonsurface to create a point for each polygon in the
>> multipolygon.
>> Thanks in advance.
>> Simon
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
