[postgis-users] asGML Error
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Aug 20 06:36:44 PDT 2008
Paragon Corporation wrote:
> David,
> We've had this error before. I think its because you didn't run the
> lwpostgis_upgrade.sql script which should be located in
> \share\contri\postgis of your postgresql install. I think that was
> how we fixed ours.
> Note your version says RELPROC="1.3.3" (needs proc upgrade)"
> Which means you are running the latest binaries but not the latest sql
> functions.
> Hope that helps,
> Leo
Yeah, I remember changing the AsGML API to add an optional version
number as the first parameter; so it seems that you haven't upgraded the
SQL procedures to match.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
