[postgis-users] problem with postgree 8.3 and mapserver 2.2.8
fsalas
fsalas at geocuba.cu
Thu Aug 21 06:17:05 PDT 2008
Hi, mark
This is a one line of the logs file, i don't know why appears "php_mapscript_42.dll" Instead "php_mapscript.dll"
My mapserver version is 2.2.8
127.0.0.1 - - [21/Aug/2008:07:47:55 -0500] "GET /salud/wrapper/drawmap.php?gszMapName=C:/ms4w/apps/salud//mapfile///salud.map&gszCurrentState=BBOX=217200,284600,228100,295300|SRS=|MAPSIZE=600,450|LAYERS=0,1,2,3,4&map_session_mode=0&run_query=0&gszPHPMapScriptModName=php_mapscript_42.dll&gszQueryCoords= HTTP/1.1" 200 1250
bets regards salas
----- Original Message -----
From: "Mark Cave-Ayland" <mark.cave-ayland at siriusit.co.uk>
To: "fsalas" <fsalas at geocuba.cu>; "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Thursday, August 21, 2008 5:17 AM
Subject: Re: [postgis-users] problem with postgree 8.3 and mapserver 2.2.8
> fsalas wrote:
>> Why? When i work with postgree 8.1 and postgis my projects mapserver is
>> ok ,
>> but whhe i change to postgree 8.3 and postgis 1.3.3 I can't see my maps
>> only a blank image
>> bets regards
>> salas
> Hi salas,
> There could several things that may have changed as part of your
> upgrade. I would suggest checking the Mapserver/PostgreSQL log files in
> order to find any error messages that will point you in the right direction.
> HTH,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
___________________________________
Dpto de Sistemas Informáticos
Oficina Central Grupo Empresarial GEOCUBA
Este mensaje esta libre de virus.
Revisado por Kaspersky Antivirus
Engine version: 4.0.1.14
Engine date: 2002/06/25
Definition count: 995840
Definition date: 2008/08/21
MDAV version: 2.2.9
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080821/14634f00/attachment.html>
