[postgis-users] postgis install error in windows
Gustavo Ces g.ces at pettra.es
Thu Aug 21 23:28:00 PDT 2008
Hi David,
    i don´t understand... There isn´t a postgis installation option when you install postgresql 8.3... You have to do it with Stack Builder, don´t you? So theorically i have a clean postgresql 8.3 installation with no postgis. There isn´t no postgis tables or functions in the postgresql 8.3 server.
    I have the old postgresql+postgis server ( the idea is to do a direct dump&restore from one server to the other). Could it be a problem?
Gus
  ----- Original Message -----
  To: PostGIS Users Discussion
  Sent: Thursday, August 21, 2008 4:09 PM
  Subject: Re: [postgis-users] postgis install error in windows
  Hola Gustavo...
  I had the same problem...
  The answer is: your postgres version includes a postgis version....
  Before you install the new version, you have to unistall the older...
  2008/8/21 Gustavo Ces <g.ces at pettra.es>
    Hi all,
        i´m trying to upgrade my postgresql version ( it was 8.2) in windows , so i' ve downloaded and installed postgresql 8.3. When i try to install postgis 1.3.3 with the Application Stack Builder and after downloading the postgis installer, appears an error
    "Error opening file for writing" ( see jpg)
    everytime it wants to copy a file to the install_folder.
    I was changed the directory name, i have downloaded postgis installation files from pgFoundry, i have changed to postgis 1.3.2 but nothing works.
    Any help?
    Thanks in advance,
    Gus
    postgis-users mailing list
    postgis-users at postgis.refractions.net
    http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080822/3a086756/attachment.html>
