[postgis-users] problem with OIDS
Obe, Regina
robe.dnd at cityofboston.gov
Tue Aug 26 07:29:21 PDT 2008
OIDS=true is obsolete because it has limitations on size and PostgreSQL in general has been trying to get people to stop using it for general user tables. Mapserver works fine for me without it and uses the gid field.
What sort of problem are you having? Could be a completely different issue or you are running a really old version of mapserver.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of fsalas
Sent: Tuesday, August 26, 2008 9:04 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] problem with OIDS
in this moment I have problems with mapserver and postgis.
This is the sentence create with shp2pgsql.exe why set the WITH (OIDS=FALSE)?;
How I can change this to OIDS=TRUE
CREATE TABLE areasalud
gid serial NOT NULL,
codasalud bigint,
"version" bigint,
descasalud character varying(40),
geoloc geometry,
CONSTRAINT areasalud_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_geoloc CHECK (ndims(geoloc) = 2),
CONSTRAINT enforce_geotype_geoloc CHECK (geometrytype(geoloc) = 'MULTIPOLYGON'::text OR geoloc IS NULL),
CONSTRAINT enforce_srid_geoloc CHECK (srid(geoloc) = 2085)
WITH (OIDS=TRUE);
ALTER TABLE areasalud OWNER TO postgres;
bets regards
Salas
___________________________________
Dpto de Sistemas Informáticos
Oficina Central Grupo Empresarial GEOCUBA
Este mensaje esta libre de virus.
Revisado por Kaspersky Antivirus
Engine version: 4.0.1.14 Engine date: 2002/06/25 Definition count: 1019980 Definition date: 2008/08/26 MDAV version: 2.2.9
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080826/51ba3a0a/attachment.html>
