[postgis-users] ST_Unioning invalid multipolygons
David Jantzen david at culturemob.com
Thu Aug 28 17:34:02 PDT 2008
Hi again,
I'm trying to ST_Union multipolygons from the Zillow neighborhood data.
When I do this I occasionally see:
NOTICE:  TopologyException: found non-noded intersection between
-73.812....
This appears to be due to invalid geometries, as the following query
returns over a hundred rows:
select * from neighborhoods where not ST_IsValid(the_geom)
Can anyone suggest a workaround here?  The resulting geometry needs to
be a multipolygon.  Also, what is ST_Is_valid actually testing for?  The
documentation isn't very explicity about the definition of validity.
Thanks,
David
